0 Members and 1 Guest are viewing this topic. Read 6881 times.
The wireless 802.11n spec is backward compatible with 802.11b and 802.11g. 'B' and 'G' operate at 2.4GHz only, so if you have a dual-band router (2.4GHz and 5GHz), as long as the 2.4GHz wireless portion is enabled, it will work.Steve
Earlier Squeezboxes and the Squeezebox Duet may not support the more recent versions of the WPA2 wireless security protocol depending on the firmware version, but the Squeezebox Touch does, so there really shouldn't be any need to reduce or "dumb down" your wireless security to WEP.Yes, dual-band routers will let you set a different security protocol for the 2.4GHz and 5GHz radios, but a dual-band router shouldn't be necessary just to accommodate the Squeezebox Touch.Steve
Can the Squeezebox Touch play music from a USB HDD without being controlled by a separate computer?
Yes, but it works better if you use a separate computer. With the USB HDD, it has to run a mini version of the serve software and can bog down if there's a large number of files.
+1I store my music files on a usb hdd that is attached to a wireless router. If i attach it to the SB, it takes a while to build some sort of an index and is painfully slow. I need to get a network drive enclosure .... USB interface is too slow.
May not help that much to go NAS, the bottleneck is really in the slow processor in the Touch, which has to do all the work a computer would normally do running the server software.
True but hopefully it should atleast help with how quickly the server running on my PC can access the drive attached to the router. Right now, it works, but its frustratingly slow.
Is there a reason you need to have the music library drive attached to the router/NAS/whatever instead of just attaching it to the PC running the server?
