0 Members and 1 Guest are viewing this topic. Read 23939 times.
From http://www.finishing.com/97/55.shtmlI'm just sayin'.............
Should we be surprised that the reviewer picked the most expensive as "the best?" Through headphones no less.
+1, curious minds want to know. I have always assumed sight bias, power of suggestion, etc.
It's a shitty platting because those 2 elements are very dissimilar and there will be eddy currents that will destroy the bond. Any claims that it wont are full of shit.Wayner
I recently completed outfitting my system with Pangea AC-14 power cords...on all my gear.
I had an idea for a power cord based on designs by Kimber and Shunyata using a run of Kimber 4VS and 8VS speaker cables.I basically expanded the 8VS braid so I could slide the 4VS cable through the center. 4VS (all 8 wires) = ground8VS (8-Hot, 8-Neutral)9awg for each leg.I got the cheap WattGate AC and IEC connectors.Total cost= $140Works well!
Shunyata has some pretty good ideas why they work. The 2 main factors they've noticed were voltage drop and current delivery being measured in each AC pulse. ... I think. I might've forgotten some details. Crappy cords restrict current and drop more voltage in that split second. In a way the power cord acts as a filter which is why it still works in the last few feet before entering a device. Geometry of the wire is a factor as well and Shunyata also uses braided wires because they reduce the effects of RFI/EMI.
You can't plate gold onto copper. It will not stick. Copper has to be first plated with nickle, then plated with the gold.Wayner
I really can say my system sounds better just from replacing three pangea AC9 with Pangea AC9SE powercords. (since three are four meters, and one a two meter, the cost is $1050. with a $200 rebate)Well worth IMO what i got in increased resolution, and better frequency response, and better bass. Way more natural sound from my Magnepan 3.6s I am VERY HAPPY with this upgrade all around the system sounds magical now.And I would say anyone with a Furman Powerfactor power conditioner MUST try a Pangea AC9SE (at least two meters long or longer) on the Furman.Though the PS Audio regenerator I have did not benefit in any useful way.The biggest bang for the buck was the amazing improvement sticking the AC9SE onto the Furman REF20i power conditioner. Though I tried it on my other conditioner, a PS Audio P600 and that did not prove positive at all, so put back the Pangea AC9 which was already there.I have not tried a lot of other brandes.. I was pretty skeptical of power cords, and then bought a cheap Pangea to try it and for the first time right off heard a difference on my amp (at that time a Forte' 4a amplifier)That got me started on Pangea. And since I have been very happy with the results, I have never needed any other cords.(though I had a Zu Birth powercord, and it sits unwanted in my closet.)
