2 vs. 3 drivers in H-Frame
0 Members and 1 Guest are viewing this topic. Read 10943 times.
bdp24
« on: 15 Aug 2012, 07:48 am »
     I was going to do this in a PM to you Danny, but I figured someone else may find the info usefull, so here goes.....
     I am preparing to put together a pair of OB H-Frame subs using the GR 12" drivers and Rythmik plate amps, and your answers to these questions will help me do so in a more informed manner. Here's what I would like your thoughts on:
     - I saw how DonS put together a pair of H-Frames under his Geddes speakers, using the subs as stands for the speakers. The H-frames were sitting upright, the two drivers in each in vertical alignment. This made me wonder.....since H-Frames are dipoles, with nulls to either side, they can be placed close to side walls without penalty. Can H-Frames be placed laying down, one side on the floor, the two drivers aligned horizontally, also without penalty? I ask because it occurred to me that a pair of H-Frames could be used as stands for a pair of old Quads. Ignoring the matter of sub placement in regard to room modes, what are your thoughts on this idea?
     - The GR 12" OB drivers have an impedence of about 12 ohms, and therefore provide an optimum load to the Rythmik amp when used as a trio, as the amp is designed to have maximum power output when looking into a four ohm load, the combined impedence of three GR drivers. This alone increases the output of the amp. Using three drivers also increases the output of the sub simply because of the fact that three drivers move more air than do two. Is this all true, and therefore three drivers per amp is preferable to two? Is there a penalty to be paid for using three drivers per amp? Is 370 watts for the three drivers enough, or would you recommend the 600 watt Rythmik amp?
     - In building the H-frames, does the distance of the box walls from the driver make a great deal of difference? For instance, two inches vs. four? How about the depth of the boxes?
     - For flush mounting of the drivers, what should the diameter of the hole for the basket be? The depth? And the through hole?
     Okay, that does it for now. Thanks---Eric.
Danny Richie
Re: 2 vs. 3 drivers in H-Frame
« Reply #1 on: 15 Aug 2012, 02:25 pm »
Yeah, no problem on any of that. You could make a whole line of them across the floor.
This is what they were designed for.
Using three in a vertical stand arrangement gets a little tall for a monitor above them. No problems using three vertically or horizontally though.
370 is enough.
Yes. It is a balance of several concerns. And it depends also on how high they play.
Added depth adds greater front to back separation, loads the drivers and increases output. However, long panel lengths are easily excited and can easily resonant, and that can be a really big deal.
If the driver plays up very high then the panel depth needs to be kept short to prevent a cavity resonance of the shorter wavelengths that would begin to propagate inside each area.
For our Super-V design about 6" to 6.5" on each side of the woofer was optimal and worked great.
Make it easy on yourself and just surface mount the driver. Then it just needs an 11" through hole. You can't see them that well deep into an H frame anyway.
bdp24
« Reply #2 on: 15 Aug 2012, 04:44 pm »
Great, thanks Danny. So for best sound (with maybe giving up a little possible output), the rule for the size of the boxes is "the smaller the better", the baffle being just big enough for the drivers and the depth no greater than necessary?---EJ.
Danny Richie
« Reply #3 on: 15 Aug 2012, 09:43 pm »
If it does get smaller (or not as deep) then there is less front back separation, less loading on the drivers, and a little less SPL.
The example of what I am using in the Super-V is just right for that application.
It could get deeper if it wasn't playing up as high, but then it better be as rock solid as a piece of granite because those woofers put a lot of pressure on those side panels.
SteveRB
« Reply #4 on: 15 Aug 2012, 11:20 pm »
Danny,
How do the drivers react on a simple straight baffle (no side pieces), say, 14"-16" wide. I was planning to do a simple mock up on a flat panel when I get the the kit, similar to image below. I will have to wait a month or two before I am able to build the spec enclosure. I assumed the SPL would be reduced and the woofer system would fall off an octave or two higher. But, I also thought the servo amps could help compensate. Thoughts?
bdp24
« Reply #5 on: 16 Aug 2012, 12:52 am »
I'll be crossing over at no higher than 100hz, so a baffle of 14" square for each driver and a cube interior depth of about the same (7" in front of and behind each driver) should be a good compromise, eh?
Danny Richie
« Reply #6 on: 16 Aug 2012, 02:14 am »
Yep, very good.
Danny Richie
« Reply #7 on: 16 Aug 2012, 02:20 am »
Danny,
The mass being moved by a pair of servo subs would just about jerk something like that over, or at least move it across the floor.
And the output would be significantly reduced. The front wave and back wave will cancel each other out too quickly, and be canceled out (to some degree) by the movement of the baffle.
SteveRB
« Reply #8 on: 16 Aug 2012, 03:16 am »
Got it. I'll book the shop time early.
Ric Schultz
« Reply #9 on: 16 Aug 2012, 05:21 pm »
I have two 12 inch servos on an 18 inch wide open baffle but have not fired them up yet to see how much bass they deliver.  I bet it will go into the low 30s.  If you did three 12s with two side by side on the bottom and then one above in the middle you would no doubt have killer low bass.  This would have to be at least 27 inches wide at the very bottom.  My speakers use three layers of highly refined 3/4" MDF with green glue in between for the baffle and base, and the brace in the back is three layers of 13 ply birch ply also using green glue.  These 85 lb. speakers will be very stable.  Check out the preliminary proto pics on my website.   I will post their low frequency response in a week or two when I measure.
Rclark
« Reply #10 on: 16 Aug 2012, 05:58 pm »
 You won't get any low bass at all. There is a guy on diyaudio.com who has a setup with like 16 18 inch woofers in OB, a WALL of subs, just a monstrous setup, and even with all that he only gets to 20hz.
 http://www.diyaudio.com/forums/multi-way/142015-my-open-baffle-dipole-beyma-tpl-150-a-118.html#post2922246
Danny Richie
« Reply #11 on: 16 Aug 2012, 06:21 pm »
Actually the servo system will force the drivers to play flat to 20Hz or less (depending on where you set the extension filter), and it will do that in on any baffle or even in free air. However, the output level will be significantly less on a flat baffle.
ebag4
« Reply #12 on: 16 Aug 2012, 10:38 pm »
What would a "U" alignment do for the servos?
Ed
Danny Richie
« Reply #13 on: 17 Aug 2012, 12:50 am »
Ed
A U frame does much of the same thing that the H frame accomplishes, but most that I have seen use a large un-braced rear section that is very resonant. They really need to be very well braced and very heavy to overcome the pressures in the U.
corndog71
  • Some people call me Rob.
« Reply #14 on: 17 Aug 2012, 02:32 pm »
Hmmm... this opens up some interesting design ideas.  What do you figure the depth should be for a u-shaped enclosure?  Would 12-13" be ok or too much?  Or how about a slightly flared U almost like a horn.
Danny Richie
« Reply #15 on: 17 Aug 2012, 02:48 pm »
The H frame divides the chamber in half and relieves a lot of pressure that a U frame will have on the side panels. It is a much better solution.
sfdoddsy
« Reply #16 on: 17 Aug 2012, 04:49 pm »
The main predictor of how low you can go for a given volume is the front to back separation between the drivers. A flat baffle of say 12 inches gives you a separation (or D) of 12 inches. Six inches to the side at the back, six inches to the center at the front.
If you add a twelve inch side piece (an H baffle) you add another six inches for the waves to travel to the back of frame, 12 inches to get to the front, and another six inches to the inside again.
In effect you are tripling the baffle width. You would need a 36 inch baffle to have the same capability as a 12 inch wide and deep H baffle.
The downside is that the deeper you make the H frame, the lower the dipole peak and other resonances.
A U frame has the same effect, but the resonances will be lower again because it acts acoustically twice as deep as the H Frame. Some recommend trying to damp this.
Many have indeed used H-Frames on their side with Quads and other dipoles.
As for using three drivers, you'll lose the force cancellation opposed drivers give and sub will shake.
I'd go to four a side, or bigger drivers if you want to stay OB.
But if you really want deep loud bass you're better off using a sealed sub like the Rhythmik to come in below 40Hz. The OB subs may play to 20Hz, but they won't play loud.
Davey
« Reply #17 on: 17 Aug 2012, 05:14 pm »
Fellas,
Sorry to interrupt here but.....an H-frame dipole woofer is not a force-cancelling configuration.  It matters not if you have one driver or sixteen, all cones are moving in the same direction during operation.  A "W"-frame configuration is where 100% force cancelling is realized since both cones are always moving in the opposite direction from each other.  I've seen a few "hybrid" configuations where the drivers are orientated 90 degrees with each other to yield a smaller width, which yields a "hybrid" force cancellation.
You do realize some even-order distortion reduction by "inverting" alternate woofers in a "H"-frame configuration, (because one cone is moving towards the magnet and the other away) but not vibration reduction from force cancellation.
Yes, there are (minor) pressure differences created in a dipole woofer configuration, but relative to closed boxes or vented boxes these are miniscule.  I don't see any problem in damping wall cavities, but remember that (most of the time) these systems are low-passed well below frequencies that would excite these panel resonances sufficiently.  Some dipole configurations are extreme...Ripole...and then you might start to see significant pressures created.
It's not correct to say a servo system will force a dipole woofer configuration to play flat to 20Hz in any condition.  We're talking about two different things here.  The filtering schemes in the sub-woofer amplifiers are 'equalization', but the servo configuration is for 'distortion reduction' and doesn't counter dipole front/back cancellation....directly.
Regarding the original query.....A third driver will yield 3.5db more output capability than two drivers.  IMO, that would be the most important reason to do it.....vice distortion, resonances, or other issues.
Dave.
« Last Edit: 17 Aug 2012, 06:34 pm by Davey »
Danny Richie
« Reply #18 on: 17 Aug 2012, 07:46 pm »
Davey is correct. There is no force cancellation in a H frame. Both drivers are (and half to be) in phase with each other even if one is inverted.
The W frame does not give you 100% force cancellation either. Since the woofers in a W frame are leaned over to about 45 degrees of vertical. They need to be facing straight up and down and opposing to get you complete force cancellation. The latest Orion uses this configuration. Unfortunately this keeps you from being about to brace the side walls as the whole area has to be open to allow a woofer to be installed through the hole.
And damping the wall cavities is a BIG deal. You don't even have to hit the resonance frequency of the panel to have a problem. The woofers themselves put a LOT of pressure on the side panels. And the flexing of the side panels can be a very large distortion. I have heard so much panel flexing in an Orion that it completed colored the bottom end.
Yep, it will still play to 20Hz easily. I will whip one out and take some free air measurements as soon as I can.
Actually our OB subs will play very loud and a pair of them are easily as loud as a woofer in a sealed box. And that is to 20Hz.
Davey
« Reply #19 on: 17 Aug 2012, 09:33 pm »
Well, when I referred to a "W"-frame configuration I meant completely parallel baffle plates.  So, a "W" that looks like this "|_|-|_|".  Sorry about that.  That configuration does have complete force cancellation.
You can skip the free-air measurements, I believe you.  Your driver may indeed play easily to 20Hz, but it's because of equalization, not the servo configuration.
A sealed box woofer will indeed play louder than an OB configuration......all other things being equal.  It will take you four OB subs to equal the SPL capability of one sealed-box woofer.....all other things being equal.
Dave.
