stands for Sonus Faber Electa
0 Members and 1 Guest are viewing this topic. Read 6026 times.
Marius
« on: 14 Aug 2012, 04:02 pm »
Hi,
Sorry for this non-Bryston question, but couldn't find an appropriate circle. A friend of mine has a set of Sonus Faber Electa's and would like to buy a set of stands. Apparently the originals are not to be found anymore. Are there aftermarket solutions you all would advice?
Marius
PRELUDE
Re: stands for Sonus Faber Electa
« Reply #1 on: 14 Aug 2012, 09:30 pm »
Hi,
Marius
Hi Marius,
Is this what you are looking for?
Are you in U.K?
Marius
« Reply #2 on: 14 Aug 2012, 09:49 pm »
Almost ! His speakers don't have the curved sides. Apparently another build of the same Electa speakers.
http://i140.photobucket.com/albums/r3/ykbucket/SonusFaberElecta.jpg
And no, I'm in the Netherlands, as is my friend.
Thanks for helping!
Marius
« Last Edit: 15 Aug 2012, 06:46 am by Marius »
PRELUDE
« Reply #3 on: 19 Aug 2012, 08:39 pm »
Thanks for helping!
Marius
I thought I could get it for you but no luck,sorry.The speaker is older then what I thought.Time is flying. :duh:
Marius
« Reply #4 on: 19 Aug 2012, 08:40 pm »
thank you so much for trying.  :thumb:
PRELUDE
« Reply #5 on: 19 Aug 2012, 09:05 pm »
Take a look at this site for aftermarket ones.They reasonably priced. :)
http://www.sanus.com/us/en/products/speaker-foundations/
fritzspeakers
  • FRITZSPEAKERS.COM
    • FRITZSPEAKERS.COM
« Reply #6 on: 21 Aug 2012, 10:02 am »
Check these stands out, available from Grant Fidelity.  They are similar to the original SF model and are adjustable from 24 to 30 inches (61-76cm) high.  Probably pretty expensive to ship from Canada to the Netherlands as they are very heavy, come fully assembled and ship in one large box.
http://shop.grantfidelity.com/Nobility-WS-1-Adjustable-Height-Speaker-Stands.html
« Last Edit: 21 Aug 2012, 11:25 am by fritzspeakers »
