Help deciding between the Decware SE84C+, Napa Acoustic NA-208A, Dayen Ampino.
0 Members and 1 Guest are viewing this topic. Read 1294 times.
HiFi Buck
Hello. I am pretty new here and am looking at building a very nice two channel audio set up on a budget. I know I am going to use a very high sensitivity speaker to mate with the integrated amplifier I decide on. The speaker will be either a Tekton Lore or an offering from Omega. So 94-98db sensitivity. I have narrowed it down to 3 different integrated amps. All 3 are a little different. Obviously most of you are familiar with the Decware amp, but the other two are not as talked about. The Napa is a hybrid tube/solid state amp and the Dayen is strictly solid state but heard that it sounds so good that it has the sound of a tube amp. I need an integrated amplifier that can play all music very well as I do not listen to just one genre of music. Thanks for the help.
