RUSH: Clockwork Angels
0 Members and 1 Guest are viewing this topic. Read 1470 times.
Rclark
« on: 9 Aug 2012, 01:17 am »
 Absolutely love Rush from their first album right up to about Signals, and they lose me after that. Got Vapor Trails, that's alright, but nowhere near the early stuff.
 Heard some tell that Clockwork Angels is a "return to form" and a lot of allusions to 2112, being that this is a concept album with a lot more of a rock edge to it.
 Count me dissappointed. I'm going to give it a few more listens, but my first go through impression was this is pretty soft rock, pretty par for the course modern Rush. Not even close to 2112. Not one song here grabbed me, none of the riffs or drum parts are especially metallic, and Geddy Lee doesn't snarl once, he sings in the way he has for years now, like an insistent, troubled woman pulling your sleeve.
 The first two tracks are a bit tepid, but it gets you thinking, okay, this is really going to take off from here.. and it never really did.
 If I'd known this going in, I wouldn't have bought it, but the reviews are all 4 stars, this album rocks, etc.
 It seems to be well recorded and some of the basslines are especially zingy. But other than that.. I think I need to give it another chance.
 I was kind of daydreaming a bit while listening, and I did click ahead through some of the songs, but that's the albums fault.
 Your thoughts?
Re: RUSH: Clockwork Angels
« Reply #1 on: 10 Sep 2012, 08:16 pm »
I like the older Rush albums, but the newer stuff hasn't moved me enough to buy one of the later albums. Presto is the latest one I own. I will not buy the new one until I have heard it. Was not on MOG last time I checked.
Rclark
« Reply #2 on: 10 Sep 2012, 08:22 pm »
 Yeah, early Rush = "Woah, that's awesome! What are you listening to!?"
 Modern version = "Woah... what ARE you listening to  :scratch:"
mvwine
« Reply #3 on: 11 Sep 2012, 07:29 pm »
I am also a long time (35 year) RUSH fan, and I quite like it. I think it's the best album since possibly Grace Under Pressure, maybe on the same level (although quite different musically) as Power Windows. I didn't really care for anything after Power Windows until they came out with this album, and I consider RUSH to be my favorite band. I think the lyrics "fit" the music better on this album - on a lot of their later works, the lyrics seem forced. Is it "Moving Pictures" or"2112"? No, but I think it rocks. :rock:
« Reply #4 on: 17 Sep 2012, 03:01 am »
It finally showed up on MOG, so I gave it a listen.
It is better than most of their more recent albums, but still not as good as any of their pre-Power Windows albums. I will probably pick it up sometime, but I am in no Rush to do it.
Rclark
« Reply #5 on: 23 Sep 2012, 04:35 am »
 I gave it another listen. It's not horrible, I think I was just expecting way too much. I give it a 5.5 out of 10, for a Rush album.
