AV-1 Pre-Built Cabinet Options
0 Members and 1 Guest are viewing this topic. Read 1935 times.
mfinalheaven
« on: 8 Aug 2012, 02:18 am »
Hi Guys,
I have an AV-1 kit that I built some test cabinets for a while back but was never finished with. I don't have the time or the tools to do it anymore so I am wondering if you guys have any suggestions on already built cabinets I can buy for use with the kit without needing anything more than a screw driver.
I know that parts express has cabinets but I believe the front and back baffles are not cut so I would need the proper tools to do the cutting. I am looking for sources that can either cut the baffles for the parts express cabinets or build the entire cabinets.
Much thanks!
gab
Re: AV-1 Pre-Built Cabinet Options
« Reply #2 on: 9 Aug 2012, 08:24 am »
wow, pretty  decent price
Hank
« Reply #3 on: 9 Aug 2012, 12:01 pm »
Yep, good pricing.
pecker
« Reply #4 on: 9 Aug 2012, 08:50 pm »
Not pre-made, but built to order.
http://diyspeakercabinets.com/
mfinalheaven
« Reply #5 on: 15 Aug 2012, 05:13 pm »
Thanks guys. Now I need to consider my options and figure out which way to go.
