What might be a good OB match for the GR SW-12-16FR OB Sub?
0 Members and 1 Guest are viewing this topic. Read 1904 times.
Trismos
Hello
I've been following this circle for a while and have enjoyed what seems to be a more 'willing to experiment' attitude here for the diy crowd. Wouldn't it be great to have the time and resources to try all of these?!
I'd like to build the Hestia... or maybe a Poultryguist baffle... But I have a pretty good sub set up. What might a good high efficiency baffle set up look like to run with a Virtue M-901?
Angaria
Re: What might be a good OB match for the GR SW-12-16FR OB Sub?
« Reply #1 on: 6 Aug 2012, 04:39 am »
Check out the top half of the Nao Note.
Or... you could try the SEOS waveguide + CD and a pro 12" woofer, if you're really after efficiency.
matevana
« Reply #2 on: 6 Aug 2012, 11:38 am »
Just build the Hestia without the low frequency driver. All of the dimensions would remain the same and they should integrate well with your existing sub. The driver cost should only be around $50 per side.
Trismos
« Reply #3 on: 3 Sep 2012, 09:25 pm »
I REALLY like what Mijknarf Has done!
http://www.audiocircle.com/index.php?topic=106249.20
