Dodd phono stage vs. upgraded Cambridge vs. Vista
0 Members and 1 Guest are viewing this topic. Read 10794 times.
S Clark
« on: 3 Aug 2012, 07:23 pm »
For several years I've had a Cambridege 640P that gets good reviews for the $, and a year or two back i started upgrading caps, then I picked up another with upgraded op amps and caps.  In the meantime, I got a deal on a Vista for a MC that I was using, and now I've just picked up Dodd.  :o :o :notworthy:
Now I get it.  The Cambridge upgrade are clearly audible, but the Vista still has better detail and imaging (at least when comparing with a Signet MC).  But what this Dodd does is simply in a different class- of course it should be.  The Cambridge and Vista are a couple of hundred bucks whereas the Dodd is over a thousand.  But holy moly what a difference!  Detail, space, bass definition, imaging, .... the list just goes on.
Now I can't say that the Dodd is the champion among the $1K+ group because I simply haven't heard them, but I can say that none of the "giant killers" even come close on what this unit delivers.  I've been watching for a while to see if any Dodd units came up for sale, but have not seen any used.  I think I understand why.
Scott
kingdeezie
Re: Dodd phono stage vs. upgraded Cambridge vs. Vista
« Reply #1 on: 3 Aug 2012, 08:04 pm »
The Dodd is pretty awesome. I had that unit when I I still had a vinyl setup. Enjoy!! :thumb:
pipper389
« Reply #2 on: 7 Mar 2013, 02:35 am »
looks like an entry level unit , maybe something i might be interested in future.
WireNut
« Reply #3 on: 7 Mar 2013, 03:09 am »
Entry level at 1K.
Ugh
Consider the Cornet2 for around $750.00 completed.
S Clark
« Reply #4 on: 7 Mar 2013, 04:57 am »
Entry level at 1K.
Ugh
Well the Cambridge is definitely and entry level unit, although hot rodded to a higher level.  The Vista is a nice step up from that, and perhaps an entry level unit for those getting in with a mid level turntable.  There is no way I'd consider the Dodd an entry level phono stage.  Like all things audiophool, I have no doubt that the Dodd can be bested, just not cheaply.
WireNut
« Reply #5 on: 7 Mar 2013, 05:09 am »
There's someone on AK that has a mod for the cambridge 640p I think that is suppose to be really good. Can't remember their user name but it's probably worth looking into for somebody that's looking to mod there cambridge phono pre.
S Clark
« Reply #6 on: 7 Mar 2013, 05:41 am »
That guy is Hypnotoad. It is a good mod, and my Cambridge has that upgrade- caps and op amps.  It does add detail, but I still like the Vista better.  I like the Dodd even more than the Vista.
fsimms
« Reply #7 on: 7 Mar 2013, 06:11 am »
I have a MiniMax Phonostage that is pretty good but my Dodd blows it away.  Get a pair of Amperex Oranges to put in the input stage of the Dodd and the increase in sound will be totally unbelievable.  A friend has an Audio Research PH7 and he says that it is as good or better than his Dodd.  However, I think he just had some Bugle Boys which are not near as good as the oranges.
Bob
WireNut
« Reply #8 on: 7 Mar 2013, 06:27 am »
Yes Hypnotod, that's the guy. Good to know you like the Vista better then the modded cambridge. I own a Vista :thumb:
Still, someday I hope to build a Cornet2 even if just for fun, or to just improving on my DIY skills.
WireNut
« Reply #9 on: 7 Mar 2013, 06:33 am »
Who is running Dodd Audio Corporation?
HAL
« Reply #10 on: 7 Mar 2013, 12:52 pm »
Gary Dodd
woodsyi
« Reply #11 on: 7 Mar 2013, 01:32 pm »
I am glad to hear that you like Gary's phono pre.  He's building me a unit to go with a Miyajima Zero mono cart.  I am going balanced and battery power to eliminate any hum what so ever.  I have tried the Zero mono on my existing phono pre and I can't get rid of the hum.  It's probably the AC powered phono stage.  I had a hum issue with it and  I solved it by going balanced.  So I am hoping Gary's balanced and battery power will do the trick for the Zero cartridge.  Of course, I am expecting fabulous sound out the Dodd phono stage. :wink:
S Clark
« Reply #12 on: 7 Mar 2013, 02:25 pm »
Miyajima Zero !! I have cartridge envy  :green:.   I have a Denon DL-102 mono that I often play through the Dodd with no noise.  Batteries solve a lot of problems.  With my pre, dac, and phono stage on batteries, I don't have a lot of noise in my system.
roscoeiii
« Reply #13 on: 7 Mar 2013, 03:04 pm »
Also jealous of the Zero. A mono cart is next on my audio to-do list...
woodsyi
« Reply #14 on: 7 Mar 2013, 03:51 pm »
What I heard above the hum was great.  Mono on mono fleshed out more details and added texture that I didn't know were there.   :thumb:
