0 Members and 1 Guest are viewing this topic. Read 5509 times.
Here is another option in that size: $103" Beovision 4. And it's only $93,050.00!Martin
has a rather long throw.....100-110" ..........range that doesn't break the bank?
- What is considered "rather long"?Us home theater guys might consider a long throw to be 20'.
Yea, that's long! But at a 100' away, a 100" screen wouldn't be visible by the folks in the last row anyway, right?There's an area on ProjectorCentral.com that allows you to enter the desired specs, including price, and it'll give you PJ units that "fit the bill".Have you seen that?Bob
They are going to put a mock up of a 90inch screen and try to imagine if that'll be good enough from the back of the chambers (up to 60ish feet away).
