0 Members and 1 Guest are viewing this topic. Read 9603 times.
So, how much are we talking about?Is it going to better my cheapie Bravo D1 DVI to Infocus SP7200?Thanks,
Does this player output 720p and 1080i format?Thanks
Hello Bill-I understand that DV-79 has a good DAC for 2-channel music. Will the AVR300 have a good enough DAC comparable to DV-79 sound quality? I had a chance to hear AVR300 with Paradigm speakers and was not impressed with this combination. This combo had recessed midrange and bloated bass. With internal DAC’s, how would you describe AVR300’s 2-channel sound characteristics when driving VSA VR-2 speakers in a 2-channel mode? Does the AVR300 have enough power to effectively drive VSA VR-2, LCR-15 and TS-150 speakers?Best regards,Alex
How is the picture using component cables?
I would be curious how the DV-79 would rank in "Secrets'" DVD Benchmark. Both the Arcam FMJ DV27 and DV-78 have ranked extremely poorly in the past.Quote from: F-100Does this player output 720p and 1080i format?ThanksGiven Bill's comments about HD-DVD and Blu-Ray, I would certainly hope so.
Quote from: Sa-donoI would be curious how the DV-79 would rank in "Secrets'" DVD Benchmark. Both the Arcam FMJ DV27 and DV-78 have ranked extremely poorly in the past.In looking for all the errors that Benchmark refers to, the DV-79 looks like film in each example. There are no digital artifacts at all. It sound impossible, but I have been staring at the damn thing all yesterday, and I can't find one digital flaw. Not one jagged line, not one frame error, nothing.
Hi Bill,Thanks for the info. Does the DV-79 sound better then CD73 when using their internal (2-channel) DAC’s?Best regards,Alex
Are you referring to their inspection of the DV-78?
The video frequency response of the player was quite good with only a slight rolloff at higher frequencies, but this didn’t seem to affect detail in playback.Overall the DV-78 is a solid offering that is improved upon with their flagship DV-27A. The 27A will be featured in our next benchmark report.
The report states that the flagship uses Silicon Image so if the DV-79 is the flagship then I'd expect it to do well. If it is using the chip used in the DV-78 then I'd expect it to have similar performance, at least in terms of deinterlacing, CUE, etc.
