How good is a RCM?
0 Members and 1 Guest are viewing this topic. Read 9546 times.
tricka
How good is a RCM?
« on: 31 Jul 2012, 10:08 pm »
Broke out the Okki Nokki last night and cleaned some vinyl with some AIS formula 6 (the 1 step - I'm lazy). Wow. Double wow.
I'd forgotten what clean vinyl sounds like. Not only a much lower noise floor but so much more detail. Great improvement.
I guess in the US most folks would be running a VPI - they seem the go over there.
Anyone else a cleaning convert?
jtwrace
    • TIPP YouTube Channel
Re: How good is a RCM?
« Reply #1 on: 31 Jul 2012, 10:14 pm »
Yes, I use a Nitty Gritty with great results.   :thumb:
tricka
« Reply #2 on: 31 Jul 2012, 10:17 pm »
what cleaning solution do you use mate?
I thought about a nitty gritty but they are hard to find here. Seem top value.
roscoeiii
« Reply #3 on: 31 Jul 2012, 10:38 pm »
Especially for really old musty, moldy records I use AP solution. It has both detergent and anti mold agents. For new records I just use the Mint cleaner (which comes with new strips for the VPI wand).
TONEPUB
« Reply #4 on: 31 Jul 2012, 10:41 pm »
Always used one.  Started with Nitty Gritty in the early 80's.  VPI and Clearaudio about 5 years ago, upgraded to Loricraft and now use the Audio Desk Systeme.
Clean is good.
roscoeiii
« Reply #5 on: 31 Jul 2012, 10:48 pm »
And Spin Clean is a great inexpensive place to start.
SteveFord
« Reply #6 on: 1 Aug 2012, 12:05 am »
VPI 17 for me.
J-Pak
« Reply #7 on: 1 Aug 2012, 01:33 am »
The most invaluable "tweak" I've added to my system was a record cleaning machine.
threadkiller
« Reply #8 on: 1 Aug 2012, 05:00 am »
Yep! A must.  VPI 16.5.  Best thing VPI makes  :lol:
roscoeiii
« Reply #9 on: 1 Aug 2012, 05:41 am »
VPI 16.5 is great. Got a great deal for a used one on eBay. Then the motor was burnt out. So I got a new motor, a full refund and a 16.5 that finally cleans like a charm.
« Reply #10 on: 1 Aug 2012, 09:11 am »
A 16.5 for me "plus" steam yes it makes a difference
Check it out from fellow A/C member DaveyW
http://daveyw.edsstuff.org/vinyl/S&VVC/
jtwrace
« Reply #11 on: 1 Aug 2012, 11:29 am »
Pure2 mostly but also have Pure Water and Enzyme.
You might want to contact kabusa.com and maybe he can help you on a NG as he does international shipping.
tricka
« Reply #12 on: 2 Aug 2012, 11:13 am »
Cool. Thanks for sharing.
Nope got a Okki Nokki from Germany: $600 on my door step. Shipping from the USA is a killer these days.
cheap-Jack
« Reply #13 on: 2 Aug 2012, 02:19 pm »
Hi.
You may call me cheap again. $600 or more to start plus detergents to paid for ever?
Not for cheap skate like me, budds. Yet I can get superb details from my many hundreds LPs (most most of them were recyled from thrift stores for only 75cents a pop) on WET play.
When I can hear the soul capturing powerful voice of Pavarotti & sentimental delicate throaty voice of Victoria de los Angeles from their 75-cent recycled LP recordings without using a RCM, I should not complain.
c-J
threadkiller
« Reply #14 on: 2 Aug 2012, 02:30 pm »
True, and agree, many goodies in the bargain bins.
But just think what you're doing to your stylus..
roscoeiii
« Reply #15 on: 2 Aug 2012, 02:39 pm »
Hi.
That's why I always try to remind people of the Spin Clean option. $70 or so to start.
Gopher
« Reply #16 on: 2 Aug 2012, 02:45 pm »
Are there any good cheapie RCMs from China these days that have spinning platter and vacuum?  Voltage wouldn't matter much as its not an audio piece and a step down  wouldn't hurt sq, and I bet theres stuff for under $500 that looks better then the VPIs.
This Amari for $313 was one I found:  http://www.cattylink.com/page287.html
Shipping is a little spendy though...
roscoeiii
« Reply #17 on: 2 Aug 2012, 02:53 pm »
Grant Fidelity sells what looks like the same RCM for $550:
http://shop.grantfidelity.com/Consonance-Vinyl-Record-Cleaning-Machine.html
And once you calculate shipping for the RCM you likned to, that one becomes a $554 RCM.
If you are going for under $500, I would grab a used VPI-16 or 16.5. (if you can live with their looks.) They are plentiful. And if you are patient you can get one for around $250-300 on eBay. And parts are easily available from VPI, as is an upgrade kit for conversion of 16 to 16.5 (a worthwhile upgrade).
cheap-Jack
« Reply #18 on: 2 Aug 2012, 02:54 pm »
Hi.
No sweats. Budd.
Against all the odds about WET play, I have been wet playing since day one I started vinyl a few years back & the same MM cartridge with its same stylus is still chiming like a nightingale.
Please don't take in gossips.
c-J
threadkiller
« Reply #19 on: 2 Aug 2012, 03:07 pm »
What is WET play? Haven't seen that before..
