Coupling vs decoupling: what does each do? which is better?
0 Members and 1 Guest are viewing this topic. Read 3040 times.
river251
I have ProAc One SCs mounted on Atlantis stands. I have a foam rubber mat, about 4x5", between speaker and stand. I have been reading about different ways to connect the speakers and stands. The Fat Dots decouple. Blue tac couples solidly (supposedly).
What happens with decoupling; why is it good? What happens with coupling (some companies make the stand fixed to the speaker)?
What effects does each have on the sound? Which is better?
Jim
Herbie
    • Herbie's Audio Lab
Re: Coupling vs decoupling: what does each do? which is better?
« Reply #1 on: 3 Aug 2012, 06:42 pm »
Hi, Jim. I recommend a set of four Square Fat Dots between each speaker and stand. A decoupling/isolation approach will bring out the best potential of the speakers, bringing out a more natural sonic result that's more faithful to the recorded event. Foam rubber, however, will not give an ideal result, because it's too slow interacting with very high-frequency acute vibrations that cause a lot of glare and grunge and foam rubber tends to introduce its own lower-frequency resonances into the vibrational environment.
The topic has been brought up before on this Circle, here:
                                         Couple vs De-couple speaker to stand?
Herbie's Audio Lab
