Denon Audio App
0 Members and 1 Guest are viewing this topic. Read 1613 times.
DaveNote
  • Without music, life would be a mistake. Nietzsche
Denon Audio App
« on: 29 Jul 2012, 02:47 pm »
For those who use iPods, iPhones and iPads with your headphones and want an equalizer to play your music, you may want to check our the Denon Audio app for 99ยข.
It allows you to equalize your own misic and as well as Internet radio stations - the basic version of Tunein is built into the app. No album covers I believe. Found one bug: crashes when stations changed when going directly from ome to another. I learned that it won't crash changing stations if you hit the stop button before changing stations. Otherwise, it works well if you want to add a little something to your headphones.
It seems to me that this may be the only equalizer app that allows you to adjust eq your own misic manually as opposed to Apple's own pre-set eq options. But I since I dont't have tunes on my Apple devices, I can't say for certain if the Denon app functions this way on your own music.
Dave
