0 Members and 1 Guest are viewing this topic. Read 9476 times.
The Tempest has indeed both, MC and MM stages, selectable and switcheable. The MC stage has a standard 47 K, and I have used it with the 0.2 mV Symphonic Line RG 8 Gold with great success. Don't think that I'd go any lower than that, though. However, again, keep in mind that the Tempest is the $3,300 SL RG 2, which SL has been tweaked and improved for nearly 2 decades. Also keep inmind that Rolf is a die-hard analog lover (with one of the largest Opera - and classical voice collection I've ever seen, & old Jazz greats), and you'll have an idea that the phono section is actually one of the priorities of the preamp.
Don't hold me to this- but I think you will need the 2mm spacer to get the most out of the Dyna/Rega combo. You might check the Rega forum or with a Rega dealer)
Furthermore, the subplatter and bearing have been upgraded as well.
I'm also wondering if having the RB600 arm rewired with the Incognito kit by BritAudio (from whom I purchased the Michell TechnoWeight) would be a better decision at this point.
