Magnepan and my Eico
0 Members and 1 Guest are viewing this topic. Read 2213 times.
SteveRB
« on: 25 Jul 2012, 04:20 pm »
Hello,
First post in this forum. I'm looking around at speaker options these days. I have been really into the open baffle DIY approach for the past few years. Now I thinking about a pair of Magnepan (1.6).
I hear different reviews and opinions on amps and power necessary for these. I have a fully restored Eico HF-81 that I love. Just wondering if the Magnepan's would leave me wanting more power...?
http://home.earthlink.net/~eico_hf81/
I'm all over the map with music: 60's folk, 90's hip hop, all types of pop and off the wall stuff.
Currently I'm running a Visaton B200 (96dB 6ohm) open baffle with a Alpha 15 for bass. I never turn the dial up further than 1/8th.
Any opinions from actual owners...?
Re: Magnepan and my Eico
« Reply #1 on: 25 Jul 2012, 08:04 pm »
Try to arrange some time with them and see if there's any magic. I don't think there will be. I wouldn't own anything less than 80W for my 1.7's, and I don't listen very loud either. I wouldn't spend a dime until I've heard the combo at a lengthy audition.
Emsquare
« Reply #2 on: 25 Jul 2012, 11:28 pm »
Not so easy to predict. The 1.6 is listed as 86dB/2.83v/m @500Hz and recommended amplification is 50-250Wrms @ 8Ω. That's a little ambitious for an Eico 81 @ 14 Watts. Most Magnepan users will find that wanting but not everyone is going to think so. Magic 8-ball says ...  'Outlook Doubtful'.
Magic 8-ball has been known to be wrong on occassion.
SteveRB
« Reply #3 on: 25 Jul 2012, 11:55 pm »
Thanks for the opinions.
There are a couple 1.6's in town on the used market; I may try to crash in on one with amp in hand. The Eico has been known to be more than 'acceptable' for medium efficient speakers (88-92dB). It really does sing with high efficient speakers.
I've had mine rebuilt from the ground up, and as i said, I use very little of it to drive my current set up.
I'm a little tight for extra cash these days, but I may also be able to get a decent SS power amp. Then I could use the pre amp outputs of the Eico to the SS then to a pair of 1.6 or 1.7's...
We'll see, I'm kind of eager for a speaker upgrade but not ready to drop $3K on a pair of GR Research V2's.
andyr
« Reply #4 on: 11 Aug 2012, 10:05 am »
Have you tried your Eico yet with the 1.6s?  :)  (I really think you will have trouble making them sound good with a lousy 14w!)  I heard some 1.7s - which are supposed to be more efficient than 1.6s - sound superb with a Magtech amp ... but that's 500w into 4ohms.  :P
Andy
Davey
« Reply #5 on: 11 Aug 2012, 03:05 pm »
If you change speakers you always have to consider changing amplifiers.
You select an amplifier based on the speakers you prefer.  It doesn't work any other way.
A 14 watt tube amplifier driving 1.6's would be like expecting your riding lawnmower to pull a 30 foot travel trailer.
Now everyone laugh at my silly analogy.  :)
Dave.
brooklyn
« Reply #6 on: 11 Aug 2012, 06:21 pm »
Having used Maggies many different times over the years I would say to go with the solid state amp and use the preamp outputs like you suggest. Maggies need power to sound their best.
SteveFord
« Reply #7 on: 11 Aug 2012, 09:33 pm »
A little blurb on the 1.7s in the current TAS said "they eat power like King Kong eats breakfast" or words to that effect so I think they'd make the Eico release the Magic Smoke.
