Purpose of wifi in blueray
0 Members and 1 Guest are viewing this topic. Read 1999 times.
ricardojoa
« on: 24 Jul 2012, 04:32 pm »
Does anyone know the purpose of wifi in blueray player and how it is used.
I dont have a unit with wifi but i just cant think of it what it is for.
Thank you
saeyedoc
Re: Purpose of wifi in blueray
« Reply #1 on: 24 Jul 2012, 04:38 pm »
Depends on the player.
Firmware upgrades, streaming using Netflix, Pandora, etc.
ricardojoa
« Reply #2 on: 24 Jul 2012, 05:46 pm »
thanks for the response. So you mean i can stream the wifi on the blueray instead of the wifi on the TV?
saeyedoc
« Reply #3 on: 24 Jul 2012, 06:07 pm »
Depends on what's on your blu-ray.
My Oppo streams Netflix, Pandora and Vudu. I can also stream using DLNA.
Don_S
« Reply #4 on: 24 Jul 2012, 06:45 pm »
My Panasonic blu-ray player streams numerous paid video sites as well as YouTube.  It links to YouTube and displays most of my favorites.  Some don't display and when I research them I get a message something like "not authorized for mobile devices"  How they determine a blu-ray player and wall-mounted widescreen are portable defies logic.  :scratch:
I ran a dedicated CAT5e cable.  The internet is also used for firmware updates.
ricardojoa
« Reply #5 on: 24 Jul 2012, 06:55 pm »
Thank you for the responses.
Can you some how use the wifi on the BR player to connect and surf the net?
saeyedoc
« Reply #6 on: 24 Jul 2012, 07:00 pm »
Not on mine
Don_S
« Reply #7 on: 24 Jul 2012, 07:33 pm »
Not on my Panasonic DMP-BDT210.  In fact navigating YouTube is even awkward. You would not want to do too much searching using it.  I create my "favorites" list using my desktop and only use the Panasonic to choose from that list.
Bob in St. Louis
« Reply #8 on: 26 Jul 2012, 02:44 pm »
It also gives you the ability to control the unit via a smart phone, tablet etc....
