SOLD: Jamo D450 Speakers & 6510 Subwoofer Phoenix,AZ
0 Members and 1 Guest are viewing this topic. Read 7301 times.
soewhatman
SOLD
Offered for sale is a pair of Jamo D450 A medium sized tower loudspeakers in good condition.  These belong to a friend who moved from a large house with an elaborate A/V setup to a small condo after she retired.  We set her up with a much smaller stereo setup, and I am assisting her in finding a home for these.  They are in perfect functioning condition, and I don't believe they were ever pushed hard knowing the owner (a female doctor whose favorite use of the stereo was listening to NPR talk radio).  She purchased them new through an A/V dealer about 8 years ago.  There are a few very small nicks along the edges and corners which I repaired with black paint, and the chrome trim strip at the top show some spotting.  See the photos for reference.
From the manufacturer specifications:
   2 1/2 Way Dual Bassreflex
   Woofer: 6 1/2"
   Midrange: 6 1/2"
   Tweeter: 1"
   Power Handling: 200W
   Frequency Range:  36 - 40000 Hz
   Impedance:  4 Ohm
   Dimensions:  7.7"x35.4"x11.8"
   Weight:  45.2 lbs
Offered for $400, local pickup in the Phoenix, AZ area.
Also offered is a Jamo Sub 6510 Subwoofer from the same system.  This is a good sized, well built subwoofer in a sealed enclosure.  Again, there are a couple of small knicks on the outside edges that I have painted in with black so they barely show.  Also, the plastic tabs that hold the front grill on are bent.  They still work, but might need to be glued at some point.
   System:  Closed
   Woofer:  10"
   Frequency Range:  25-150 Hz
   Impedance:  22k
   Phase:  adj. 0-180 deg.
   Cut Off Freq:  40 - 150 Hz
   Amplifier Rated Output:  650 peak
   Limiter:  Yes
   Dimensions:  375mm x 375mm x 375mm
Offered for $300, local pickup in the Phoenix, AZ area.
I have hooked these up to my stereo and verified that everything works fine and they sound excellent.  I will not get into the subjective sound of the speakers, and let a prospective buyer form their own opinion.
The speakers and subwoofer can be purchased together for $650.
I am happy to make arrangements to demonstrate these in my less than acoustically perfect listening environment.  Just shoot me a message.
« Last Edit: 8 Nov 2013, 05:34 pm by soewhatman »
soewhatman
Re: FS: Jamo D450 Speakers & 6510 Subwoofer Phoenix,AZ
« Reply #1 on: 16 Aug 2012, 03:01 pm »
Bumb & Price Reduction
$350 for the Speakers
$250 for the Sub
$500 for Everything
Great price for some quality built speakers with high WAF.  These are not the same as the HTIB Jamo junk that shows up in the big box stores.
I would consider trades for a quality turntable or a cool running digital amplifier.
Rick.
soewhatman
« Reply #2 on: 31 Aug 2012, 04:21 am »
Last price drop to $400 for the speakers and subwoofer.   This is a lot of speaker for the current price.
Rick.
kwebber9
« Reply #3 on: 8 Nov 2013, 04:41 pm »
I am aware this ad is quite old but I would be very interested if the set up is still available.  I sent a PM to the OP but also wanted to post here as well.
