0 Members and 1 Guest are viewing this topic. Read 6644 times.
Dspeaker Antimode 8033c or Dspeaker Dual Core 2.0. I have a 2.2 system and use the 8033s with great success. I'll be taking delivery of the D/C 2.0 late next week...will post review accordingly.http://www.dspeaker.com/http://www.simplifiaudio.com/online_store/dspeaker_store.htmlChris
Hi,I am planning a 2.1 setup with SongTowers. I just ordered my SongTowers and already have an Rythmic F15. So, I have been hunting for electonics and I was at this crossroads, buy a receiver with a sub out or separates with Parasound 2100 and an amp. I have asked for help at AVS and was suggested to post here to get better/relevant replies. so, please enlighten me.1. what all options are there to integrate a sub with the SongTowers?2. what is the best way?I understand it depends on what type of equipment you have but I want to know what all options are out there, for my understanding. I am noob and trying to get the basics.TIA
Velodyne SMS-1. $339.00 on Amazon.
Forget the receiver. Buy a companion power amp for the Parasound 2100...a Parasound amp would be fine...a Halo even better. Sorry, it's really not clear from your statement if you already own the 2100, but separates is the way to go. The SongTowers deserve decent amplification. The 2100 mentioned had sub outs , so you're set. Just buy some Blue Jeans IC's for your run to the F15 at the length you need for your set up.
I thinkg the 2100 parasound is a decent and affordable preamp with great features. Just make sure the you find your best sub placements. i think since this preamp have no processing, find the right spot to integrate with the sub becomes an issue. With receiver, you can play with distance, and not worry about too much on location and still get pretty cent sound.
I am sorry but I was in the assumption that it does have some kind of processing since it has sub out. I am sure I am 100% wrong.
The Parasound 2100 Preamplifier does have buffered circuits to sum an analog stereo input into mono sub outputs and it does have an adjustable 20Hz - 140Hz low-pass filter, but it does not have digital processing that can adjust time delay to compensate for distance, as do most surround sound processors/receivers and some subwoofer processors.Steve
My friend just built a pair of Rythmik subs. If yours has the same plate amp, it has all you'll ever need in the way of adjustments and tuning. Now just go find a nice pre-amp with sub outs( perhaps a used AVA to match the amp) as the it seems the Rythmik wants to be feed by line level. ( IC's from the sub out of your pre-amp)
Absolutely. That's one of the most versatile plate amps for tuning I've ever seen. .....at least without spending thousands.
I quick peek into AVA pre, looks like none has a sub out, any thoughts?
All of the preamps that AVA sell have two sets of pre-outs (left and right) that you can use to hook up one or more subs. Cornelis
Thank you for pointing out. But I initially I looked at this one http://www.audiocircle.com/index.php?topic=107971.0 I don't see any pre-outs.And if its separate left and right pre-outs, how do I connect the sub woofer? I believe I will be connecting to left and right on the plate amp, its like feeding full range and use the crossover of the sub, right?
That one is a rebuilt Dynaco Super PAS 3 pre with AVA curcuits, so it may not have two sets of preouts. All the new ones do, I think Frank has been building them this way for quite a while. And yes, thats how I would hook it up. Hope this helps. Cornelis
