FS: Crest CA9 - Monster Amp $450 [PRICE DROP]
0 Members and 1 Guest are viewing this topic. Read 3415 times.
« on: 20 Jul 2012, 06:54 pm »
These sell new for $1300, and used for around $600.
My price - $450 plus shipping from Denver (80204).  Paypal preferred.
This is a MONSTER amp - 800 watts into 4 ohms, and not those crappy class D watts - this is a PURE ANALOG amp and is able to grip those woofers like no tomorrow.
Condition - functionally perfect, but there are a couple of scratches as seen in the pics, and the rack mount ears are slightly bent.
Features:
    Legendary over-built power supply
    Toroidal power transformer
    Latest generation of high-speed, wide-bandwidth output devices
    Twin-tunnel cooling with back-to-front air flow
    Dual, rear-mounted, continuously variable-speed fans
    Balanced male and female XLR inputs with switch-configurable XLR polarity and sensitivity selection
    Speakon® or five-way binding post output connectors (market dependent)
    Stereo, parallel, bridged-mono mode selector switch
    Ground-lift switch
    Front panel circuit-breaker switch
    Recessed, stepped attenuators
    SIGNAL present/active, PROTECT and ACL LED's
    Modular construction
    Powder-coated steel chassis
Specifications:
    1kHz, 0.01% THD+N:
        8 ohm Stereo Power: 600 watt
        4 ohm Stereo Power: 900 watt
        2 ohm Stereo Power: 1000 watt
        8 ohm Bridged Mono Power: 1800 watt
        4 ohm Bridged Mono Power: 2000 watt
    20Hz-20kHz, 0.1% THD+N:
        8 ohm Stereo Power: 550 watt
        4 ohm Stereo Power: 800 watt
        2 ohm Stereo Power: 900 watt
        8 ohm Bridged Mono Power: 1600 watt
        4 ohm Bridged Mono Power: 1800 watt
    Max RMS Output Voltage (each channel): 82V
    Max Peak Output Voltage: 116V
    Frequency Response (+0 / -0.3dB, 1W/8ohm): 20Hz-20kHz, -3dB@135kHz
    THD+N: <0.01%
    Damping Factor: 400:1
    Class: H
    Dimensions (Height x Width x Depth):
        3.5" x 19" x 18"
        89mm x 483mm x 457mm
    Weight: 47 lbs. (21.33 kg)
« Last Edit: 27 Dec 2013, 07:12 pm by Tyson »
Re: FS: Crest CA9 - Monster Bass Amp
« Reply #1 on: 24 Jul 2012, 07:23 pm »
Price Drop.
parisphoto
« Reply #2 on: 26 Jul 2012, 02:40 am »
PM Sent
« Reply #3 on: 27 Jul 2012, 03:18 pm »
Hi parisphoto,
I replied to your PM, but hadn't heard back - are you still interested in the amp?
parisphoto
« Reply #4 on: 28 Jul 2012, 02:25 pm »
PM sent.
Re: FS: Crest CA9 - Monster Bass Amp [PRICE DROP]
« Reply #5 on: 31 Jul 2012, 01:00 am »
Price Drop.
« Reply #6 on: 31 Aug 2012, 11:02 pm »
Bump.
« Reply #7 on: 18 Oct 2012, 02:58 am »
BUMP!!!
« Reply #8 on: 24 Nov 2012, 04:05 am »
Price Drop.
parisphoto
« Reply #9 on: 24 Nov 2012, 11:56 pm »
PM sent.
« Reply #10 on: 27 Dec 2013, 07:06 pm »
Really need to move this amp, we are staging our home and I'd rather sell it and not have to move it with us to the new home.
Re: FS: Crest CA9 - Monster Amp $450 [PRICE DROP]
« Reply #11 on: 19 Jun 2014, 08:59 pm »
Bump
jackman
« Reply #12 on: 20 Jun 2014, 01:09 am »
Guys, this is a monster amp for very little money.  It's a tank and Tyson is a great seller. Someone needs to snap it up.
