Tape Loop Specs..
0 Members and 1 Guest are viewing this topic. Read 2371 times.
WEEZ
Tape Loop Specs..
« on: 31 May 2004, 11:56 pm »
Hello,
It appears that the tape input spec is 10k on the B60. Does anybody know the spec on the tape output?
WEEZ
WEEZ
Tape Loop Specs..
« Reply #1 on: 2 Jun 2004, 01:07 am »
Hello? Anybody home?
  • The Demo is Everything!
    • http://www.bryston.com
Tape Loop Specs..
« Reply #2 on: 4 Jun 2004, 10:18 pm »
HI Weez,
I will check on that one for you.
james
WEEZ
Tape Loop Specs..
« Reply #3 on: 17 Jun 2004, 01:00 am »
James-
I know it might be a trivial question but.....
WEEZ
Tape Loop Specs..
« Reply #4 on: 17 Jun 2004, 12:22 pm »
Yes I guess it's time for trival answer then.
Sorry about that - I forwarded it to engineering and they have not got back to me yet - I will follow up today with them for you.
james
Tape Loop Specs..
« Reply #5 on: 21 Jun 2004, 01:56 pm »
B60 TAPE OUT - LESS THAN 100 OHMS
james
WEEZ
Tape Loop Specs..
« Reply #6 on: 21 Jun 2004, 02:45 pm »
Thank you,
WEEZ
