GlassWare LV-Regulator for SqueezeBox Touch
0 Members and 1 Guest are viewing this topic. Read 1635 times.
mboxler
« on: 13 Jul 2012, 02:36 pm »
I've read many articles stating that replacing the stock 5V power supply for the SB Touch is a good start at improving sound quality.  I decided to try a DIY approach.
http://glass-ware.stores.yahoo.net/lvregulatorkit.html
It is configured in a full-wave center-tapped configuration.  I have powered it up, and measure 5.01 volts on the output.
My question is this...how can I test the PS with a load before using it on the SB Touch?  I don't have any special equipment to simulate this.
Thanks, Mike
mgalusha
Re: GlassWare LV-Regulator for SqueezeBox Touch
« Reply #1 on: 13 Jul 2012, 03:44 pm »
If you put a 10 ohm resistor across the load that will pull .5A, which is, I believe, about what the SB Touch draws. RadioShack has them for $2.19.
http://www.radioshack.com/product/index.jsp?productId=2062291
mike
mboxler
« Reply #2 on: 13 Jul 2012, 05:25 pm »
 :duh:
I = V/R... .5 = 5/10
Just happen to have one of those.  Will give it a try.
