DAC options?
0 Members and 1 Guest are viewing this topic. Read 1293 times.
skenderbeu
DAC options?
« on: 12 Jul 2012, 01:31 pm »
I am looking into a DAC but I found out the choices are way too many .I was wondering what are few suggestions I should look into ? Possibly remote control capable .Maybe a list of 3
Thank you
Letitroll98
  • Too loud is just right
Re: DAC options?
« Reply #1 on: 12 Jul 2012, 03:25 pm »
Here's a list of a bit more than three.
https://docs.google.com/spreadsheet/ccc?key=0Ai84C5yKnfvAdGFBSjNWdjZOYTdPaFpYVHVBVHFDbVE#gid=0
Also check out the Cheap and Cheerful circle and the Discless circle, both have a zillion threads on various DACs.  There are so many options it may help if you set a price range and options needed such as USB, 24/96 or 24/192, extra inputs, volume control, etc.
But to address your post directly, Grant Fidelity 11, DacMagic, Maverick.
adydula
Re: DAC options?
« Reply #2 on: 12 Jul 2012, 06:26 pm »
It depends on your use and your budget etc...there are indeed MANY dacs out there.
I use a HRT Technologies Music Streamer ii +....its a $350 Dac thats excellent. Its a USB DAC.
I also have a $99 ODAC on the was which is a USB dac thats has excellent specs etc .
All the best
Alex
