0 Members and 1 Guest are viewing this topic. Read 6478 times.
Willie, does replacing the 2a3s count as DIY?
The power supply is the key to a great SET, moreso a "Modern Designed" power supply has more influence than the type of output tube, as far as sound is concerned..... That coupled with a thoughtfully designed layout of the amp, quality wiring and parts, will get you to "World Class " performance.
Yeah I was just looking at Clarity caps on a Parts Connextion ad, I did not look see these TC series cap..... say you've had good results with them ..eh !...I only hope they're better than Solens .............I DO NOT use electrolytics if I have any chioce in the matter. Thanks Willie
Have you tried these PS caps? https://www.partsconnexion.com/capacitor_film_clarity_tc.htmlVery low ESR specs, these will make a massive difference in your PS performance. I just got them for both my SET and my 6SN7 tube preamp. I have a Mundorf M-Tube Cap that is similar to the Clarity caps in the SET amp and the difference between that and an electrolytic was amazing, even though the electrolytic was in parallel with 2 80 uF oil filled motor run caps. The Clarity Caps have about an order of magnitude less ESR than the Mundorf Tube Caps, so I expect it will be even better.
Please do keep us posted on what you find with these caps. I have been looking at them for a new preamp but it will be a while before I can get to this part of the design. It would be great to hear what others experience with them in the mean time.
