0 Members and 2 Guests are viewing this topic. Read 18834 times.
I'm starting this thread in response to another were there is science saying the human ear cannot really hear bass under 40hz that well in relation to 3.5khz.With that said, let's have a good debate!Jim
The human ear is not as sensitive to 40Hz as it it is to 3.5kHz. See below the lowermost curve. This represents the thresholds (lowest intensity that can be perceived) across frequencies for individuals with normal hearing. Threshold at 40Hz is about 50dBSPL while at 3.5kHz its -5dBSPL. You can see that sensitivity continues to drop at even lower frequencies. AP
I would like to see the comments of a neurologist engaged in researching how our auditory systems work and the part our brains play in the perception of auditory stimuli. There has been research done on the areas of the brain stimulated by different genres of music but I am unaware of any research on the perceptual threshold of musical instruments or works of music based on the frequencies the instrument can produce or the harmonics contained in a piece of music. To clear up earlier misconceptions about how loud bass frequencies need to be before we can hear them, here is a graph and explanation cut and pasted from the Hyperphysics website The measured threshold of hearing curve shows that the sound intensity required to be heard is quite different for different frequencies. The standard threshold of hearing at 1000 Hz is nominally taken to be 0 dB, but the actual curves show the measured threshold at 1000 Hz to be about 4 dB. There is marked discrimination against low frequencies so that about 60 dB is required to be heard at 30 Hz. The maximum sensitivity at about 3500 to 4000 Hz is related to the resonance of the auditory canal.As you can see from the above explanation all we need to hear 32Hz is a SPL of 60dB and 20hz can be perceived at about a SPL of 73dB. This is why we can successfully reproduce and hear bass frequencies in our listening rooms. Obviously it doesn't need to be as loud as blast of thunder to be audible. I think one of the things that has been overlooked is the sensitivity our entire body to the spectrum of low frequency sound. As the frequency decreases our entire body becomes increasingly more sensitive to sonic stimulation. By the time a frequency of about 32Hz is reached it is generally agreed that sound is as much felt by the body as heard by the ear. Below 32hz you have increasingly transitioned to feeling the sound rather than just hearing it with your ears.I think this sensation is one reason that accurately reproduced bass can be so addictive for many of us, myself included.Scottyhttp://hyperphysics.phy-astr.gsu.edu/hbase/Sound/earcrv.html#c1
You are in the minority on this one....If the Munson Curves were correct, the amount of amplification required to produce bass that could be heard/discerned would be physically impossible. That by itself blows a huge hole in his theory, wouldn't ya think
