ok to leave record on the platter?
0 Members and 1 Guest are viewing this topic. Read 3969 times.
stump4545
« on: 11 Jul 2012, 02:04 pm »
is it ok to leave record on the platter overnight or a couple of days?
with the tt dustcover on.
Devil Doc
  • On the road to Perdition
Re: ok to leave record on the platter?
« Reply #1 on: 11 Jul 2012, 02:27 pm »
Unless you suffer from Audiophilia Nervosa, I don't see any problem.
Doc
JohnR
« Reply #2 on: 11 Jul 2012, 02:29 pm »
I do, but I'm lazy  :shake:  :lol:
vinyl_guy
« Reply #3 on: 11 Jul 2012, 03:27 pm »
I've been known to do it from time to time, both with and without the dust cover, and neither the record nor the TT have suffered. I just make sure I run a carbon fiber brush over the record to pick up any dust before I put it away.
kgturner
« Reply #4 on: 11 Jul 2012, 04:20 pm »
Vinyl is a fragile media, but it's not THAT fragile. You'll be fine.
Kevin T
Sonny
« Reply #5 on: 11 Jul 2012, 04:29 pm »
yep...it's my "DUST COVER"! :thumb:
Wayner
« Reply #6 on: 11 Jul 2012, 08:57 pm »
Hopefully it's not in direct sunlight......
richidoo
« Reply #7 on: 11 Jul 2012, 10:23 pm »
Don't leave it on the platter without dust cover for 3 months including the time you patched and sanded the ceiling before painting, especially if it is Miles Davis Porgy and Bess.
orthobiz
« Reply #8 on: 12 Jul 2012, 11:21 pm »
No, it's not OK.
Paul
stump4545
« Reply #9 on: 27 Jul 2012, 02:45 pm »
is it ok to leave record on the platter for weeks with dustcover over turntable?  is cool right?
woodsyi
« Reply #10 on: 27 Jul 2012, 02:53 pm »
No, not because anything bad will happen to either the TT or the disc but that you are not spinning for weeks! 8)
jjc1
« Reply #11 on: 27 Jul 2012, 03:38 pm »
  Just put a record on the turntable that you utterly hate, like the Barbara Streisand album I use, and forget about it!
