Discwashers?
0 Members and 1 Guest are viewing this topic. Read 1881 times.
Castanza
Discwashers?
« on: 6 Feb 2003, 02:20 pm »
I just recently built a new rack, and i am able to use my old turntable (yamaha). It has been over 10 years, but it still works fine. My question, is regarding the vinyl. In the past I used the discwasher to clean & remove dust, is this still the best method? Also I have the old stylus cleaner as well, that has the mirror on 1 side, and felt on the other.
duff138
    • http://www.audiocircle.com/circles/modules.php?set_albumName=album18&op=modload&name=gallery&file=in
Discwashers?
« Reply #1 on: 6 Feb 2003, 03:42 pm »
Disc Doctor miracle cleaner.  More expensive, but definitely worth it.
Psychicanimal
Discwashers?
« Reply #2 on: 7 Feb 2003, 01:07 am »
I always use the Discwasher and a few drops of demineralized water to remove dust before playing my records.  There's a trick to using it and takes time to learn.  It is not to *wash* records, though...
