Windows update not working????
0 Members and 1 Guest are viewing this topic. Read 1151 times.
David C
  • Don't try and lay no boogie woogie on the king
« on: 7 Jul 2012, 07:50 pm »
thought someone may know the solution. When I try and run windows update (XP) it just sits on the IE screen that says it is checking the ActiveX file then nothing. I can't see my update history , to the left, as it is greyed out. Any suggestions welcome
thanks in advance
WGH
Re: Windows update not working????
« Reply #1 on: 7 Jul 2012, 08:37 pm »
Here are a few suggestions that come to mind, ranging from fast and easy to time consuming.
Fix #1 - Shut down and restart your computer then try Windows Update again.
Fix #2 - Update Windows Update Agent http://msdn.microsoft.com/en-us/library/windows/desktop/aa387285%28v=vs.85%29.aspx
Fix #3 - Use System Restore to roll windows back to an earlier date when everything worked.
Fix #4 - Search Google for "Windows update not working in XP"
            http://www.fanhow.com/knowhow:Fix_Windows_Update_not_working_in_Windo ws_XP_51749347
Fix #5 - XP's No-Reformat, Nondestructive Total-Rebuild Option
            http://www.informationweek.com/news/windows/operatingsystems/189400897
Wayne
David C
« Reply #2 on: 9 Jul 2012, 12:53 pm »
Wayne
thank you for the tips. The system restore worked. It reloaded some DLL files.
I noticed when I ran Update it came back and said three dll files were "valid" so it fixed them
thanks again
