Ping Davey
0 Members and 1 Guest are viewing this topic. Read 1712 times.
Jian
Ping Davey
« on: 6 Jul 2012, 03:38 pm »
I am doing some experiments with my Sound Lab speakers. Would you please design a crossover for me based upon Mr. Linkwitz's active crossover? I need a one way, high pass at 500 hz, 6 db crossover.
Thank you very much!
Davey
Re: Ping Davey
« Reply #1 on: 7 Jul 2012, 04:25 am »
A one-way "crossover" is just a filter.  (First order is just a simple series capacitor.)
The capacitor value should be.....1/(2pi * 500 * ampinputR)
Add a shunt resistor in parallel with your amplifier input resistance to "adjust" it so a standard value capacitor is yielded from the computation.
Dave.
Jian
Re: Ping Davey
« Reply #2 on: 7 Jul 2012, 06:48 pm »
Hi Dave!
It is very nice to meet you here!
I didn't state it clearly. I meant to build an active crossover. Sound Lab speakers have two step up transforms. One is for frequency over 500 hz and another one is for under 500 hz. Basically, I am trying to replace the passive crossover with an active one. I will use the active crossover for high/mid step up transform while runing the bass transform full range.
I just bought a cheap dbx 223 to try it out and am going to try it to see if I can get good results. So, I don't need it for now. If the result is promising, I may find better sounding active crossover.
Thanks again!
Jian
rw@cn
Re: Ping Davey
« Reply #3 on: 8 Jul 2012, 03:09 pm »
Hi Dave!
Thanks again!
Jian
Have you contacted anyone at Sound Lab ?
neolith
Re: Ping Davey
« Reply #4 on: 8 Jul 2012, 07:07 pm »
For what you want to do, there really is no neded to go to an active 1st order HP filter.  As Davey said you just have to insert a cap in series with the input of the amplifier. The formula at  500 hz simplifies to 318/R nF where R is the impedance of your amp in kOhms. If C is an not a E-12 value, then you can use the next E-12 value above C and calculate a new R (318/C) and then place a shunt resistor in parallel with amp input to change load impedance to match R. The shunt resistor will equal R*Z/(Z-R) where Z is the amp impedance.
Using a series cap in this manner was what Magnepan did with their XO-1 units for biamping the IIx and early IIIx  speakers.
Jian
Re: Ping Davey
« Reply #5 on: 11 Jul 2012, 12:59 pm »
Thanks neolith! I understand it now.
