SOLD LM 3886 Chip Amp - SOLD - thanks Randy
0 Members and 1 Guest are viewing this topic. Read 1033 times.
walkern
« on: 5 Jul 2012, 12:54 pm »
I bought two sets of boards and components from an e-bay seller a few months ago, and assembled this amp to evaluate the potential of this type of amp.  The boards are from www.chipamp.com.  Parts are the standard associated with the kit, and the transformer is an Antek 300VA 24 volt.  The chassis front panel was scarred up in two places when it arrived, so the manufacturer sent me a free replacement (which I am using in the other amp that I'm keeping).  All totaled, with the wire, connectors, amp and power supply boards and components, heatsinks, free chassis etc, I'm thinking I've got about $120 invested in this guy.  It works perfectly, and will drive 4 or 8 ohm speakers without issue.  Total power is probably in the neighborhood of 50 wpc into 8 ohms.  I don't need both amps, so I'm selling this one.  If you look carefully in the photos you can see the touched up areas on the front panel (far left top, and center top), and I can send close ups if need be. The on/off switch is on the back, as well as the heatsinks, inputs and outputs. Asking $85 plus shipping, CONUS only.  No original box, but will be packed very securely.
« Last Edit: 5 Jul 2012, 08:31 pm by walkern »
randytsuch
Re: FS: LM 3886 Chip Amp
« Reply #1 on: 5 Jul 2012, 01:44 pm »
pm sent
roymail
  • Roy in TX
Re: SOLD LM 3886 Chip Amp - SOLD - thanks Randy
« Reply #2 on: 9 Jul 2012, 02:57 pm »
Neil, tried to send a reply but your inbox is full.  :duh:
