0 Members and 1 Guest are viewing this topic. Read 17227 times.
I think TONEPUB did hit the nail on the head. I think you have to design your system backwards. The amplifier/speaker relationship has to be established first, before you start going upstream. Inefficient speakers and a less then adequate tube amp will not bring happiness. If you jump over to the SET amp circle guys, they are all in the very low power amps with very high efficiency speakers. This has been a problem throughout audio from the very beginning of days. Mismatched speakers and amps always leads to the very unhappy listener.The speakers you are thinking about will need some power, so a SS or hybrid amp is going to be your best shot. If you want to sweeten the SS a bit, then the tube preamp is certainly in line.Also, the old myth that all tubes is bad, is just that, a myth. If you want that, then you need to find different speakers, like something in the 92-93db/m/w range.Wayner
70 watts is a lot of power Jim. You still driving Maggies?
Sounds nice Jim.A big 70 watt tube amp like that can probably drive just about anything. Summer won't last forever!
Synergy is the most important aspect of any system.low sensitivity speakers like high power and big tube power amps generate alot of heat and they are expensive to re tube. i like tube power amplifiers and i am willing to put up with the extra heat and maintainence involved with them. i like tube preamplifiers that are fast and neutral.in my experience warm euphonic tube preamplifiers are sluggish when used with tube power amplifiers they rob detail and speed and bring too much warmth to the sound. when done right tubes are all about the midrange and that is where the music lives.I notice that some of you guys like to argue too much. we are all stereo fanatics here and if someone has a different opinion it is what it is so just let it go and act like a good neighbor. life is too short for petty disagreements....WCW III
My question is how is one going to audition the speaker/amp combo accurately and honestly without an accurate/natural volume control?? Cheers.
Its a bit of a crap shoot like anything else in audio when the bottom line is synergy. I wasn't able to audition any pieces of my setup and did everything loosely by the numbers to start. Then tried to always have options to improve or send back my choice just in case. Haven't had to so far-Knock on wood. How you listen, nearfield vs. a larger open seating position, room size all that comes into play. As always luck is involved but minimized if your thorough to begin with. I'm not a numbers, measuring kind of guy at all but this step required I be to a certain extent. After that step its been all by ear but I rarely buy something I can't send back or tweak to some extent. Hopefully that helps with your question....
