0 Members and 1 Guest are viewing this topic. Read 16409 times.
......There are absolutely no active components in the ABX box, nothing to "mask" or "ruin" the system sound. What you have set up is exactly what you are listening too. With identical components in the test chains, you can use the ABX box to listen to interconnects, speaker cables, or even high end fuses too. Even more fun.....
From mgalusha Welcome to the lab. See link http://www.audiocircle.com/index.php?topic=71571.0 If this ABX Tester is offered for sale by AVA then we have a potential problem with what amounts to a promotional post in the Lab Circle by a vendor that might be better placed within the Audio by Van Alstine Circle in the form of a sticky.Scotty
I see no reason to limit discussion in a hidden , barely traveled circle. That said it has to stay civil. I am shocked at how quickly the anti abx folks attacked. If you don't like it don't use it.
DBT may be based on science, but, it is clearly an incomplete science at best.
Enter the test mode and all the indicator lamps are turned off, the starting point is randomized the dispaly lights up saying "Test 1". Listen away, make notes, and when you want to, press the test button again. This will then switch to Test 2 and the power amp under test will switch to the other power amp, or -- maybe not. This depends upon the random number generator making life difficult for you. Listen again, make notes again, and press test again and switch to Test 3. Repeat for the entire 8 test program session.
Forget about DBT. To me, the real value of the ABX test box is not to prove anything to anyone except for the owner or renter of the test box. Imagine having an ABX test box and you want to see how your tube amp compares to your friend's SS amp because you're considering purchasing the same amp. You can use the ABX test box to determine if you prefer the sound of one amp over the other. And being able to change amps on the fly would be wonderful. The test box would also be very useful for borrowing items from your local high end audio store to test the potential significance of an "upgrade" before you buy it. I've been looking for a device like this for 15 years. Price notwithstanding, if you can think of a better way to make such a comparison, I'd like to hear it.
Exactly! I doubt Frank is using it blind. For me I would love to use it to listen to compare a few amps. I would not use it blindly. That said I don't understand why people are calling DBT statistically weak. You may say the data is weak but don't think that makes data statistically weak.
Hi John,Please tell me why our box is not an ABX box? Is simply misnamed? If so what should it be called?It does allow double blind testing. What am I missing?Thanks in advance for your response.Frank
