Power up bryston amp
0 Members and 1 Guest are viewing this topic. Read 1952 times.
marco
« on: 29 May 2004, 11:11 am »
I use a sp1.7, spv1 and three 3bsst, i want, when power up the sp1.7 also the rest starts up. I put two wires in de sp 1.7. The green in the "on/of" hole and the blanc in the "c" hole, on the first 3bsst i put the green in the left 'in' side en the blanc in de richt `'in`' side.
nothing happend, when i look in the menu i can only config other stuff.
What to do?
Greetings Marco
jethro
« Reply #1 on: 29 May 2004, 12:19 pm »
You shouldn't have to set anything up in the SP-1.7's menu unless you are using the Aux trigger (which you are not).  You have to setup  your amp to be controlled by the 12 volt trigger. If you haven't done this, I believe you need to move the "EXTERNAL TURN-ON" switch to "EXTERNAL" and the "POWER-UP" switch to "LOCAL". At least I think these are the correct settings. I don't own an SST, yet, but this is covered in the manual.
marco
« Reply #2 on: 29 May 2004, 02:41 pm »
yep, it works, with one button all starts up, great.
Thanks.
