BDA-1: can I use both outputs RCA & XLR at same time to different sources ?
0 Members and 1 Guest are viewing this topic. Read 6026 times.
zeiter
Is there an issue if I was to use the BDA-1 outputs at the same time ( balanced and unbalanced ) to connect to  two different sources ? One would be going to my BP6 pre amp , and the other to a headphone amp ( tape monitor on BP6 is already taken ). Thanks
Phil A
No issue - I do that - the balanced for the main system and the RCAs go to the other side of the wall in the bedroom system
zeiter
Perfect, thanks
alexone
...same here :D
this way i can listen to music from the BDP-1 which is in turn controlled by my iphone even if the doors are closed :thumb:
al.
zeiter
How about a similar situation, but a little bit more complex. Can I use the BCD-1 digital out to a DAC, and still use the XLR or RCA to let's say a headphone amp ? I know using the digital out, will turn the unit into a CD transport, but not sure if it's safe or even if it will still send analog signal through it's analog outputs ?
  • The Demo is Everything!
    • http://www.bryston.com
...same here :D
al.
No problem.
james
zeiter
No problem.
james
James, is it OK for my  second question for the BCD-1? In your reply, you're quoting the BDA-1 question .  Thanks
Hi,
Yes it will still send the analog outputs a signal.
james
BrysTony
I am currently using the balanced outputs on the BDA-1 in my main system; however, based on this thread I decided that I could use the single-ended outputs for a secondary integrated amp.  After hooking it up only one channel had sound.  After much trouble shooting I found that both single ended outputs worked only if I disconnected the balanced cables.  This is counter to the answers to this thread.  Do I have a problem with the BDA-1 or is it working as designed?
Tony
Tony
Hi Tony
Please email Mike at Bryston and we will check it out.  [email protected]
SHV
"After much trouble shooting I found that both single ended outputs worked only if I disconnected the balanced cables."
It should work...before I got the SP3, I  did two "zones" with BDP/BDA unbalanced to SP1.7 and balanced to Parasound pre-amp; worked without problems.
BrysTony
Hi Tony
Thanks, James.  I have emailed Mike.
Tony
BrysTony
Mike Pickett sent a very prompt response to me saying that it should drive both the balanced and single-ended outputs with no problem.  He suggested that it was likely that one of the balanced cables cables had pin 2 shorted to ground and that I should swap the right and left balanced cables to see if the problem moved.  It did so I installed another set of balanced cables that I had on hand and all works perfectly.
This is another example of Bryston's unequalled support to its customers.  Kudos to Mike and James!  :thumb: :thumb:
Tony
