Thank You James
0 Members and 1 Guest are viewing this topic. Read 1889 times.
Chicago
Thank You James
« on: 22 Jun 2012, 04:16 am »
James,
Thanks for the suggestion of Zero Surge.  The folks were a pleasure to deal with and the unit seems to work great.  I believe I did notice some filtering of noise with it.  I only have the BP 25 and BCD-1 plugged into it with the 4Bsst going right into the wall.  It will hold me until I get the BIT but next on my wish list is the BDP/BDA combo.
Mike
saveloy
Re: Thank You James
« Reply #1 on: 22 Jun 2012, 03:45 pm »
Just wait until you get the BDP/BDA combo.  You'll want to kiss James then!
Kyri
  • The Demo is Everything!
    • http://www.bryston.com
Re: Thank You James
« Reply #2 on: 22 Jun 2012, 03:47 pm »
Kyri
Ok as long as there is no tell-tale lipstick :oops:
james
1oldguy
Re: Thank You James
« Reply #3 on: 25 Jun 2012, 11:43 am »
Thank You James and gang at Bryston......
It may have taken some getting used to but I could never give up the Bryston/B&W sound.
That is indeed a winning combo right their folks.
vegasdave
Re: Thank You James
« Reply #4 on: 27 Jun 2012, 01:39 am »
Cool, sounds good.
