Tanzanite w/ Sub
0 Members and 1 Guest are viewing this topic. Read 4403 times.
aboroth00
Tanzanite w/ Sub
« on: 20 Jun 2012, 12:33 pm »
Hello there,
New tanzanite owner here.  I purchased a pair of sealed tanzanites second hand and i'm planning to use them with a sub.  I was wondering if any other Selah owners out there are currently using their bookshelves with subs and how they are implementing that in their setup!
Marbles
Re: Tanzanite w/ Sub
« Reply #1 on: 20 Jun 2012, 01:45 pm »
I have a pair of regular Tanzanites as rear surrounds and a pair of custom in-wall Tanzanites as side surrounds in my main HT.  I use 4 sealed Dymaxion (Thanks Christof) GR Research/Rythmik servo subs.
Front speakers are Salk HT3's, with an HTC center.
This is one dymaxion sub:
aboroth00
« Reply #2 on: 20 Jun 2012, 07:21 pm »
I was talking about a strictly 2-channel setup.  But those subs look absolutely fabulous!
I also have reservations about using the tanzanites in a HT setup due to their low sensitivity.  At 84db/1watt/1m, they seem rather inefficient for HT applications.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« Reply #3 on: 21 Jun 2012, 01:33 am »
For 2-channel you can let them roll off naturally to the subwoofer (60hz) or add an active high pass filter (60-80hz).
HT is possible depending on how far you sit from them and what levels you need. Keep in mind that the sensitivity is conservatively rated.
LadyDog
« Reply #4 on: 21 Jun 2012, 02:35 am »
I use Tanzantes in the HT environment with no issues.
Beautiful sub Rob.  Chris makes some beautiful things.  Hope all is well with you.
aboroth00
« Reply #5 on: 22 Jun 2012, 09:36 pm »
Thanks for chiming in Rick.  Personally for my application, the size of my room, and the levels i listen at.  The tanzanites probably wouldn't cut it.  But that's no knock on them, I just much prefer them for music.
What would you do in this application?  I would think cutting them off with a HP filter would be preferable preventing lower frequencies from being played through the bookshelves, thus reducing distortion, and increasing headroom.
Any suggestions on a high pass?  Or should I have a passive highpass custom made?
Rick Craig
  • Selah Audio
« Reply #6 on: 23 Jun 2012, 12:52 am »
An active highpass is best.
aboroth00
« Reply #7 on: 25 Jun 2012, 10:43 pm »
Any recommendations on a quality high pass?  I'm in need of a LP and HP with subwoofer controls (phase, volume).
Rick Craig
  • Selah Audio
« Reply #8 on: 25 Jun 2012, 10:50 pm »
The DEQX HD Express.
aboroth00
« Reply #9 on: 26 Jun 2012, 09:18 pm »
Holy Moly that's expensive.  I was thinking along the lines of something much less expensive <500$.  Thoughts on the SMS-1, Minidsp, NHT x2, Paradigm X30?  Marchand stuff?
Rick Craig
  • Selah Audio
« Reply #10 on: 26 Jun 2012, 09:46 pm »
I've used the X30 and it would work great.
