Hiface driver problems - NEVER MIND - SOLVED
0 Members and 1 Guest are viewing this topic. Read 1116 times.
abernardi
« on: 20 Jun 2012, 05:18 am »
I recently picked up a Mapleshade modded Hiface USB-S/PDIF adapter.  For some reason I can't seem to install the driver on my 2011 i5 2.3GHz Mac Mini running OS 10.7.1.  I downloaded the appropriate driver from M2Tech and it appears to install successfully.  I restart and go to the Sound Pref pane and the driver isn't there.  All that's there is the Internal Speakers and MEUSLCD1 which I believe is the HDMI driver.
I have tried to install the driver on my iMac running 10.6.8 and the same thing happens.  I know I'm doing something stupid...help  :oops:
If you read this far, I figured it out... I copied the driver installer off the dmg and onto my local drive.  I didn't read anywhere that you need to do that, but I might have missed it.
