0 Members and 1 Guest are viewing this topic. Read 10702 times.
Regardless of the phones (Grados can be an exception here as they are tuned with their own cable) they all benefit from a good after market cable ...I highly recommend that you buy a used one at good price (40% off ???) instead of rolling your own ... as these cables are neither interconnects nor speaker cables or should are they they are a little bit of both ... CheersSunil.
"Sennheiser veil". Wonder if there is an easy way to mod them...
On 600/650 - easy way to remove the "veil" is by removing the foam around the cushions - it take a few minutes only and the easiest mod - if you do not like it - put it right back in ... the result is like listening to speakers without the grill cloth For 555 - if it is too bright - I do not know - see if you are able to boost your bass from amp / source ...Cheers
