0 Members and 1 Guest are viewing this topic. Read 8044 times.
Would a larger room provide a better listening space?
My vote is for staying in your dedicated room. i say this because you should have a space that makes you happy. at some point something should truly belong to you . that room should make you happy even down to decor. if you cannot even get that type of freedom in your own room then things are out of hand. the bigger space is going to come with "compromises and change" do not fool yourself into thinking other wise. you already see this , you just want to hope for better , understandable. but with some women , one compromise sets up the next compromise and etc which all works towards her real goal that you never saw coming from day one. sad but true words . so stick with the small roomand be happy. i would then focus on improving the small room's acoustics and improve the sytem if needed
Keep the existing system and get a new system for the other room. Then you can see what flexibility you'll have in terms of WAF. If you find that it's going to work out well, then you can sell the other system or keep it. If not, then you'll have a secondary system in the common area.Bryan
