Conrad Johnson ET3 vs Doge 8 Preamps
0 Members and 1 Guest are viewing this topic. Read 2397 times.
Robin Hood
« on: 15 Jun 2012, 04:33 am »
Has anyone compared this two preamps? I read the website reviews of preamps or other audio gear and I often get more confused than ever as these reviews often imply that everything is great.
So I readily accept that both these preamps are great but if your preamp budget was a maximum of $3,000, which tube preamp would you choose and why?
I believe there is no right or wrong answer here but I would like opinions. I sometimes liken choices such as this to declaring who is the most beautiful woman in the world. Among my top ten there are no losers and in my fantasy world I would be very happy with any of of the ten.
DTB300
Re: Conrad Johnson ET3 vs Doge 8 Preamps
« Reply #1 on: 15 Jun 2012, 12:43 pm »
NOTE:  I have not heard the Doge 8.
The ET3 is a nice tube Pre Amp for $2500, but is much improved in the ET3SE with the Teflon Caps.  The ET3SE is $4000 MSRP - you can probably get it for $3600.  Getting the SE upgrade later on will cost a little over $2k.  So if you are going to get the ET3, save up another few hundred and get the SE version.
Tubes:  Tube replacement cost will be higher in the Doge due to the number of tubes.
ET3 only needs ONE tube - 6922/6DJ8/7DJ8
Doge 8 needs EIGHT tubes - 4 12AX7, and 4 12AT7
