0 Members and 1 Guest are viewing this topic. Read 8702 times.
That's a sweet DAC but you do have to hit a switch to go from 96 to 192, and it doesn't support hi-rez. It's the DAC I own, though, and I like it (I don't listen to hi-rez).
When do you get your speakers? Maybe you'd like to try my Bolder EE dac with Dexa op amps in it since my system is torn down? Of course it has the good fuse and tube in it as well. Probably pushing $2k into this unit now.
I would seriously consider the Ayre QB-9. Though, it's USB only. 24/192 and UAC2 compliant means no proprietary drivers needed ever, i.e., works with Linux (the future of all music servers) juts fine. Works great with Jim's Salkstream servers, too.With my HT-2 TL's, a pair of Quicksilver Silver 88 monoblocks and Jim's Salkstream, the sound is detailed and divine. Can listen for hours and never get an iota of fatigue.The Ayre does 24/192 but what it does with 16/44.1 material is superb as well. Again, it's USB only but I think that is one of its strengths.
So, how would I use this [Ayre QB-9] with non USB sources?
So, how would I use this with non USB sources?.......Peter
you wouldn't. you said that the majority for you listening is via a media server. with the qb-9 you would have to commit to USB only. not a bad thing, in my humble opinion.
Take a look at the Wyred4Sound DAC1, has everything the DAC2 does minus the preamp function. It now has 24/192 USB, which appears you do not need. Nice DAC!
