Yes they would pair very nicely, and in addition to the excellent suggestions so far you could put B&K power amps in there as well, albeit somewhat more rare on the market than Adcom or Rotel et al, IMHO a step above them in SQ.
how would you rate B&K amp vs Hafler amps (and indeed Parasound)?I am going to trawl through ebay etc and see what can be found.thanksTom
The older the better with B&K, the early amps like the ST202 easily trounce Hafler, Parasound, or any of the popular midfi lines. Their famous, or infamous, first product, the ST140 is way too underpowered for your needs, but the model that Van Alstine claims was stolen from him was used for many of those early products with higher outputs. As the years went by the product line became more ergonomically friendly and nicer looking, as well as improved QC, but some say not as magically sounding as the earlier models. But I think even the last Reference 200.2 is a darn fine amp. Since the company is now defunct, you can find them used at advantageous prices.
thank you for those specifics.is the age (and defunktness of the co) a concern if issues develop with B&K? I guess that's my slight concern about the older gear from out of business companies.TOm
I think you have to worry the most about out of business (or even out of production) solid state amps. Transistors usually have very short production runs before the 'new and improved' version is out. This can lead to limited supply just a few years after the amp was made.
I think you have to worry the most about out of business (or even out of production) solid state amps. Transistors usually have very short production runs before the 'new and improved' version is out. This can lead to limited supply just a few years after the amp was made.Unless the preamp has IC's (chips also can have limited production lives) in the design you shouldn't have problems getting it fixed.I've heard that Qinpu in my system. It really is an overachiever. No remote though. Do a search in AC's trading post for Qinpu. There was one for sale, though it was the model just below the 6 moons reviewed model, last year IIRC and it was well within your budget and has remote and tone controls (I think). I've also heard that amp and it is also quite good for the dough.
The Rotel rb1080 at $400 strikes me as a good deal. Would it pair best with a Rotel such as rc1070?
NAD C356BEE. Has everything you asked for and a warranty.http://app.audiogon.com/listings/nad-c356bee-integrated-amplifier-with-warranty-and-free--4
Don't get hung up on simple power ratings. Many mass market power ratings are for "empty" watts (better to look for a beefy power supply and higher wattage ratings at low impedances). If you look carefully into the ratings you'll find XXX watts at 1,000 Hz at 8 ohms, which is great for a steady load on a test bench but in the "real" world of actual (reactive) speaker loads??
Except that one of the things he asked for was "definitely not less than 100w at 8 ohms. Preferably higher."The 150W/ch NAD 375BEE was the model previously discussed, but that one is $1099 rather than $599 for the 80W/ch NAD 356BEE.Steve
Except that one of the things he asked for was "definitely not less than 100w at 8 ohms. Preferably higher."The 150W/ch NAD 375BEE was the model previously discussed, but that one is $1099 rather than $599 for the 80W/ch NAD 356BEE.http://www.spearitsound.com/product.cgi?group=70&product=2927Steve
I can run a sub if the amp has what is described as - "one variable level pre-amp output"?
Point taken. How do I assess the specs to make sure I am getting "beefy power supply and higher wattage ratings at low impedances" ?ie I am looking for alot of good clean power as you say. Which and what numbers will indicate this to me? Excuse my relative ignorance in these matters, that's why I need to get clarification! thanksTOm
