28bs have landed
bud1451
Re: 28bs have landed
« Reply #20 on: 15 Jun 2012, 12:33 am »
The room is about 13ft wide where the speakers are located, and about 15ft at the opposite end. The Prodigies are 6ft from the front wall and 16 inches from the side walls and 8ft apart. My listening position is 10ft from the speakers and about another 11ft from the listening position to the back wall. I am currently happy with the sound I'm getting but may move around the subs. The big black boxes behind the prodigies are two stacked Mirage bpss 210 subwoofers, I have two per channel, each one has two 10" woofers servo controlled set at 50hz.
mkaiser
« Reply #21 on: 16 Jun 2012, 09:46 pm »
Hi Bud,
Bryston Electronics w/ Martin Logan loudspeakers in something special. I too have a Bryston/Martin Logan setup and couldn't be happier.... and such an easy speaker to set up.  :thumb:
Mark
vegasdave
« Reply #22 on: 19 Jun 2012, 07:26 am »
Hi Bud,
Mark
Cool, but I always read that planars and electrostats are tricky to set up.
mkaiser
« Reply #23 on: 19 Jun 2012, 04:43 pm »
Cool, but I always read that planars and electrostats are tricky to set up./quote]
Don't believe everything you read. Up until now i thought the same thing.
1oldguy
« Reply #24 on: 19 Jun 2012, 04:43 pm »
You must be having a blast with the 28's......judging from the performance I'm now getting from the 7B sst2.
bud1451
« Reply #25 on: 19 Jun 2012, 08:41 pm »
Yes I am having a blast with the 28bs, they are a set up in performance from my previous 7bsst2
spinner
« Reply #26 on: 19 Jun 2012, 10:00 pm »
  In what ways are they better? :scratch:
vegasdave
« Reply #27 on: 20 Jun 2012, 07:47 am »
I would like to know too...
vegasdave
« Reply #28 on: 20 Jun 2012, 07:47 am »
Ok, thanks.
rmurray
« Reply #29 on: 21 Jun 2012, 09:05 pm »
 So why are the 28s nicer than the good old 7Bs? :lol:
srb
« Reply #30 on: 21 Jun 2012, 09:30 pm »
I own neither, but from reading a good deal about them, the conclusion I have drawn is that even if the higher wattage of the 28BSST2 compared to the 7BSST2 is not needed for a particular speaker/room/dB level, the 28BSST2 has a sonic advantage due to:
1.  approximately twice the watts in Class A mode before going to Class A/B
2.  a larger power transformer (and power supply capacitance?)
Whether this is worth $9000 more ($19,200 versus $10,200) can only be answered by those that can afford it.  My personal budget is $2K, so I won't likely even be seeing a 4BSST2 for some years to come until a used one is down to that price!
spinner
« Reply #31 on: 21 Jun 2012, 09:34 pm »
 Thanks for that insight. It makes sense if we are splitting hairs and it is worth the price for this kind of haircut :lol: For me the 4b is a great value. :thumb:
rmurray
« Reply #32 on: 21 Jun 2012, 09:41 pm »
 Okay ,there it is..more time in class A due to greater power ect ect. I'm sure this  only matters as to what volume you require in a given set up. ( room size, speakers  and so on). If one doesn't require great spls then what is the extra cost for if the smaller amps go do the trick?
vegasdave
« Reply #33 on: 24 Jun 2012, 05:40 am »
Good question. The 4BSST goes as loud as I can stand it without clipping.
mkaiser
« Reply #34 on: 28 Jun 2012, 05:16 pm »
Hi Bud1451,
Sorry to hear about your misfortune? in life to have to sell your entire system especially after owning the 28's for just a few weeks.
Hopefully the future is more fair to you if you decide to get back into high-end audio.
best regards,
Mark
werd
« Reply #35 on: 28 Jun 2012, 10:38 pm »
Whats the trick? If you are into the sweet spot the bigger amps are better with Bryston. If you want to have parties and casually walk around in front your system then the 4B is more then enough. Both are legitament reasons for owing nice systems but more power in the sweet spot listening is always beneficial.
rmurray
« Reply #36 on: 28 Jun 2012, 11:56 pm »
 The 4B is sweet as well if have well matched speakers and a matching size room :rock:
vegasdave
« Reply #37 on: 29 Jun 2012, 05:42 am »
This is true...
tdinut
  • Joe aka Joeinid on other forums.
    • Audioshark Forum
« Reply #38 on: 29 Jun 2012, 07:27 am »
Hi Bud1451,
best regards,
Mark
Did I miss something? Everything OK Bud? My fingers are crossed.
SoundGame
« Reply #39 on: 29 Jun 2012, 11:47 am »
I don't see Bud1451 making a post, indicating that he's selling off everything - mkaiser, how did you become aware of this?  Bud1451 - if this is the case, I feel for you and your situation and hope for all the best.  Cheers.
