What Universal Player Or Wait?
0 Members and 1 Guest are viewing this topic. Read 1315 times.
Hank Rearden
« on: 26 May 2004, 06:10 pm »
I am curious what you would do. I am in the market for a Universal Player that I can have modified for better sound without having to spend thousands of $$$. I am mainly interested in audio ability rather than video ability. However, I will be upgrading my T.V. within the next year to HDTV and want something that can benefit from newer technology. I was considering the Denon 2200 but am not sure if Denon will be coming out with a replacement in the same price range. I also was considering the Pioneer DV-563A but have read mixed reviews. Any thoughts would be very appreciated.
Russtafarian
  • Typical reaction to the music I play
« Reply #1 on: 26 May 2004, 10:04 pm »
I don't think the whole hi-rez, digital link, bass management is going to get sorted out for another year or so.  I'm sick of waiting.  There are only a couple firewire equipped players and nothing to plug them into but $4k HT receivers.  No thanks.
For under $150 it's hard to beat the 563A.  Just make sure you get one with the latest firmware update to avoid problems playing back recently released DVD-As.  It sounds O.K. out of the box but really has potential with some modifications.  I've put about $200 worth of transformers, caps and hexfreds into mine and it's now singing quite nicely.  Certainly sounds better than any of the other digital sources I've had in my system over the past five years (DV45-A, SCD-C555ES, MSB Link DAC, all unmodified).
The only thing that bugs me about it is that many of the playback options (repeat, stereo/m-ch switch, etc) are buried in a gui menu requiring a monitor.  But this is probably an issue with most if not all multi-format players.
JoshK
« Reply #2 on: 26 May 2004, 10:07 pm »
I personally think you'd be better off getting a cheap universal and a real CD player.   Pick up a Jolida 100 for music and 563a for the rest of the stuff.
My $.02
