0 Members and 1 Guest are viewing this topic. Read 7469 times.
TJHUB,Thanks for the insight and for the hope that some of my recordings may sound much better down the road. I'm pretty much at the beginning of my audio journey, and it's obviously a far cry from where you're at. I hope to upgrade my electronics as budget allows, but it will be a while until I can do that. In the mean time, I may be able to slip some 703 panels past my wife, but we'll see how that goes.
I have noticed poorer recordings where before I got my Salks I did not...Any tips on basic room treatments or where to begin would be appriciated
This could be its own thread (or own forum for that matter).The number one thing I would suggest is to understand your room, and that means measurements.I would recommend starting by downloading REW (Room EQ Wizard) here:http://www.hometheatershack.com/roomeq/Assuming you have a cheap laptop or can find one, all you need is an inexpensive soundcard and a calibrated mic (I got mine here http://www.cross-spectrum.com/ ).There is a good forum on Hometheatershack as well for tips and tricks.Also, if you are patient enough to make it through a pretty dry read, here is a great book on room accoustics:http://www.amazon.com/Floyd-Toole/e/B001JS2MQ2TIP (The last chapter is a great summary - I would recommend to start there first and then the sections on bass management)Good luck!
Hi Guys. Don't forget that picking up a different version of the same album can get you back to good sound. Some "remastered" versions are too bright. Ive got a Pink Floyd CD that is HARSH. I also have one that sounds right. I love having a vinyl rig to find older recordings. 2 cents
not sure what you mean by "start with the room, then treatments"?
