ELLA and VMPS RM-2
0 Members and 1 Guest are viewing this topic. Read 1845 times.
PTC
ELLA and VMPS RM-2
« on: 26 May 2004, 01:56 am »
Would the Ella be a good match for the mids and highs for VMPS RM-2 in a biamp situation? Thanks,Paul
Kevin P
    • http://www.diycable.com
ELLA and VMPS RM-2
« Reply #1 on: 26 May 2004, 02:36 am »
PTC:   I don't really have any input because I don't have any experience with the speaker or application.   Brian can probably give you better advice concerning this type of question than I.   The Ella is pretty forgiving of load so if the mid/tweet are anything near a reasonable load there shouldn't be a problem in terms of driving them.
JoshK
ELLA and VMPS RM-2
« Reply #2 on: 26 May 2004, 03:07 am »
if the amp can handle a load that dips to just below 4R (as Kevin suggested) I wouldn't see why it wouldn't work.  I have used a Cary V12 full range on my RM40s and while it didn't have the upmost control at loud volumes it did fairly well and pushing the speakers.  In a biamp situation I would imagine a tube amp such as an ELLA should work out nice.
hmen
ELLA and VMPS RM-2
« Reply #3 on: 10 Jun 2004, 08:08 pm »
I was using a pair of Decware Zen model C's for the top of my RM2's and they worked fine. The Ella should have no problems.
