FS: Black Sand Silver Reference MKV Power Cord 2.0m - SOLD
0 Members and 1 Guest are viewing this topic. Read 1821 times.
ipy
US$279 plus postage.  In very good/excellent condition.
Quote from the manufacturer's site :
"....The Silver Reference latest version, the MK V includes updates to provide better performance than ever before. A truly reference-level cable.
Black Sand Cable has applied several propietary technologies to make this one of the best reviewed cables in years. The Silver Reference can be used on any device but is the best power cord for amps and power-hungry devices. ($75/m over 3m)
Every component has been cryo treated twice Terminated with WATTGATE'S TOP OF THE LINE 330iAG / 350 iAG (Gold or Silver) Series. This cord can be configured for 20amp use. Email for a quote Proprietary 11.5 AWG 3 Silver/Copper blended conductor twisted pair internal wire alignment that has been treated to prevent corrosion and oxidization Entire assembly is EMF & RF shielded not once but twice with our own proprietary dual shield system Silver/Copper annealing process Silver/Copper blended core Wound dielectric Audio grade outer jacket X 2. Both are cryo treated New braiding technique that creates an active level of shielding X 2 Entire assembly is demagnetized with our own proprietary system. A first in the industry! Temperature range: -40ºC to +90ºC Voltage rating: 600 volts (Tested at over 1850 watts!) Max. Amps @ 120V: 60 All terminations, IEC and male end are treated with Furutech Nano prior to final assembly Final cord is bench tested and burned in before it goes out the door"
Actual images of the power cord
« Last Edit: 30 Nov 2012, 07:19 pm by ipy »
ipy
Re: FS: Black Sand Silver Reference MKV Power Cord 2.0m - SOLD
« Reply #1 on: 17 Jun 2012, 08:15 am »
US$249 plus postage.
