Crackling and loosing right channel on ia7
0 Members and 1 Guest are viewing this topic. Read 1440 times.
jackslater1
« on: 1 Jun 2012, 01:37 pm »
Dear Jason,
I had been a very appy owner of a ia7 amp upgraded to v2 since it started to make some cracklings and loose sound on right channel after few minutes of use. The sound on right channel usually comes back for few sec, then ends for few secs... There are cracklings when the sound is coming back.
Is that something you have seen sometimes? Do you have guess on components I could check/replace to fix it?
Many thanks in advance for your help
Jérémie (from France)
