Onkyo TX-SR608 7.2 RECEIVER
0 Members and 1 Guest are viewing this topic. Read 820 times.
gnars
« on: 1 Jun 2012, 11:42 am »
ONKYO TX-SR608 BLACK.
WITH REMOTE, CALIB. MIC, SET UP GUIDE, REMOTE CONTROL CODES MANUAL, Owners MANUAL, Antennas, SEE Pictures
WITH ORIGINAL BOX AND PACKING. Double Boxed for shipping
CONDITION, EXCELLENT ELECTRONICS, COSMETICS 8-9 FOR LITE HDMI SCRATCHES on Back panel, OTHER WISE A 9 ALL THE WAY AROUND.
$275.00 OBO + shipping
Shipping to USA 48 via FED EX - Canada Via USPS
Pay Pal no fees
 For Pictures
http://app.audiogon.com/listings/onkyo-tx-sr608-7-2-channel-dig-receiver--2
Product Information
Sure, you can call it an "entry-level" A/V receiver. But when you witness the full potential of the TX-SR608, you'll know the level you're entering is far beyond the ordinary. For a start, you get HDMI inputs for simple hook-up of all your high-definition sources. Complementing HDMI on the input front, you have an analog RGB video input for connecting your PC, and a universal port for Onkyo peripherals. All video sources, regardless of resolution, can be upscaled to big and beautiful 1080p via HDMI and Faroudja DCDi Cinema. Audio processing incorporates quality Burr-Brown DACs, lossless Dolby and DTS codecs, and the expanded surround formats of Audyssey DSX and Dolby Pro Logic IIz. Three-stage inverted Darlington circuitry and jitter-cleaning technology work to ensure extremely precise and faithful amplification. In recognition of the TX-SR608's outstanding A/V prowess, it has been awarded THX Select2 Plus certification.
The TX-SR608 has six of the latest HDMI® 1.4a inputs for simple hook-up of all your high-def sources. HDMI 1.4a also brings compatibility with the new 3D video format, as well as an Audio Return Channel from your display back to the receiver.
Complementing HDMI on the input front, you have an analog RGB video input for connecting your PC, and a Universal Port for Onkyo peripherals. All video sources, regardless of resolution, can be upscaled to big and beautiful 1080p via HDMI and Faroudja DCDi Cinema™.
Audio processing incorporates quality Burr-Brown DACs, lossless Dolby and DTS codecs, and the expanded surround formats of Audyssey DSX™ and Dolby Pro Logic® IIz.
Three-stage inverted Darlington circuitry and jitter-cleaning technology work to ensure extremely precise and faithful amplification. In recognition of the TX-SR608’s outstanding A/V prowess, it has been awarded THX® Select2 Plus Certification.
Key Features
Channels 7.2 Channel
Amplifier Output Details 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 7 channel(s) ( surround )
 Sound Effects CinemaFILTER
HDMI Switching Yes
Built-in Decoders DTS-HD Master Audio, Dolby Digital Plus, Dolby Pro Logic IIz, Dolby TrueHD
 Receiver Tuner Type Digital
Receiver Tuner Bands AM/FM
Response Bandwidth 5 - 100000 Hz
Technical Features
Input Impedance 47 kOhm
Input Sensitivity 200 mV
Connectivity
Coaxial Digital Input Yes
Optical Digital Input Yes
Headphone Jack Yes
Miscellaneous
Color Black
Remote Control Type Universal remote control
THX certified Yes
