Test Build
0 Members and 1 Guest are viewing this topic. Read 2455 times.
mjock3
Test Build
« on: 31 May 2012, 01:28 am »
I want to put the Ncore's together temporarily so that I can take a listen while waiting for enclosures. (long story) I have a few questions on how to accomplish this. I plan on putting them on some particle board, how would I hold them in place? Another question is how do I deal with the grounding issues, not so much the power ground but the balanced ground?
Mark
jtwrace
    • TIPP YouTube Channel
Re: Test Build
« Reply #1 on: 31 May 2012, 01:35 am »
Mark
Gravity is your friend.   :wink:
Wire the XLR normal and also tie AMPON to the ground and it will be fine.
bhakti
Re: Test Build
« Reply #2 on: 31 May 2012, 01:35 am »
here's a way to assemble on someone elses fancy monoblocks.
mjock3
Re: Test Build
« Reply #3 on: 1 Jun 2012, 07:06 pm »
Thanks for answering both questions. Hope to try it later today!
richidoo
Re: Test Build
« Reply #4 on: 1 Jun 2012, 07:16 pm »
   :lol:
Be safe with the exposed voltages. A new object in the house will invite critters to sniff, or toddlers to lick...
